楼主: dantolc03
[分享] Fanuc 5X Mill 2025
发表于 2025-12-8 15:02:35 | 显示全部楼层
发表于 2025-12-8 20:30:41 | 显示全部楼层
感觉论坛里面还藏着不少外国友人
发表于 2025-12-9 17:13:20 | 显示全部楼层
也没什么用了,由于某些原因这些后处理已经被放弃了,里面问题也是特别多
发表于 2025-12-10 12:04:33 来自手机 | 显示全部楼层
Thanks for sharing!
发表于 2025-12-11 10:45:00 | 显示全部楼层
xinruyu369 发表于 2025-12-8 10:00
不加密源码收2个元宝意思一下
西门子828D 的车铣复合后处理,发一个
发表于 2025-12-12 00:48:05 | 显示全部楼层
发表于 2025-12-12 00:54:39 | 显示全部楼层
不加密源码收2个元宝意思一下
mcpost这个后缀是不是用了代码混淆的
26
发表于 2025-12-12 08:51:37 | 显示全部楼层
不加密源码收2个元宝意思一下
你好,有没有MC 2025版的源代码?  代码优化过的
26
发表于 2025-12-13 09:20:24 | 显示全部楼层
不加密源码收2个元宝意思一下
# Revision log (newest first):
# CNC 02/15/2024 - (27.00) - Initial post update for Mastercam 2025
# CNC 05/17/23  -  (26.07) Initial post update for Mastercam 2024
# CNC 04/26/2023 - (25.07) - D-51675 Corrected issue with repositioning in TCP
#                            Corrected issue with unnecessary clamping outputs & clamping with three axis and axis sub
#                            Corrected issue with feed in per revolution when tapping
# CNC 02/22/2023 - (25.06) - S-101810/R-33818 Corrected output settings for output_rotaries_at_twp.
#                            Updated verbiage for mi1$ (Inc. distance to retract & unwind rotaries.)
#                            Corrected issue with offset at null (ptlchg0$).
# CNC 01/19/2023 - (25.05) - D-51043/R-33031 Corrected approach/retract when using linking with multiple passes.
# CNC 01/19/2023 - (25.04) - D-50646/R-33094 Corrected work offset outputs values
#                            D-50627/R-33262 Corrected missing output drilling cycles
#                            D-50647/R-33270 Modified drilling text to display correctly in dropdown
你好,请问你2023的有上面的修订优化吗?
# CNC 06/17/2022 - (25.03) - Initial post update for Mastercam 2023
# CNC 01/04/2022 - (24.03) - Corrected issue with C axis values
# CNC 09/20/2021 - (24.02) - Corrected alarm illegal command in TCP mode
# CNC 07/07/2021 - (24.01) - Added support for axis sub
# CNC 04/06/2021 - (24.00) - Initial post update for Mastercam 2022
发表于 2025-12-13 11:38:03 | 显示全部楼层
fanuc系统在国内的机床由rtcp吗
GMT+8, 2026-11-5 04:11
