查看: 484|回复: 3
[求助] Required some Haas
发表于 2026-1-1 19:22:34 | 显示全部楼层 |阅读模式
Required Haas 5X MILL.mcpost Associated Files in exchange of Gold Coins
# Haas UMC-1000 Mill.mcam-mmd
# Haas UMC-1000SS Mill.mcam-mmd
# Haas UMC-1250 Mill.mcam-mmd
# Haas UMC-1250SS Mill.mcam-mmd
# Haas UMC-1500-DUO Mill.mcam-mmd
# Haas UMC-1500SS-DUO Mill.mcam-mmd
# Haas UMC-1600-H Mill.mcam-mmd
# Haas UMC-500 Mill.mcam-mmd
# Haas UMC-500SS Mill.mcam-mmd
# Haas UMC-350HD Mill.mcam-mmd
# Haas UMC-350 Mill.mcam-mmd
# Haas VF-2TR.mcam-mmd
# Haas VF-5TR.mcam-mmd
# Haas VF-6TR.mcam-mmd
发表于 2026-1-2 09:43:31 | 显示全部楼层
If you need the source code, please email me
e-mail:573651577@
qq.com
发表于 2026-1-5 10:49:02 | 显示全部楼层
这是哈斯后处理程序头
发表于 2026-1-5 14:58:27 | 显示全部楼层
pmx0$ # Multiaxis toolpath calculations    ###/// boy9981@163.com
    last_praw = vequ(praw)
    prv_last_praw = vequ(prv_praw)
    extend$ = EXT_EXT@
    extend$ = STD_STD@
    if bailout,
        #exitpost$
    if gcode$ = ELEVEN@, # & mill5$ <> TWO@,
        next_op_is_linking = opinfo(107, 1, 0)
        next_op_is_linking = (next_op_is_linking = TOOL_OP_LINKING@ | next_op_is_linking = TOOL_OP_DRILL5AX_SAFETYZONE@)
        tool_axial_vector_x = vmap(vtoolx$, matt(m1_wrto_matb))
        p_solve_rotaries(tool_axial_vector_x, tool_axial_vector_y, tool_axial_vector_z)
        p_choose_rotary_solution
        if db_lvl_trg$, p_drw_line(xraw, yraw, zraw, uraw, vraw, wraw)
        result1 = fsg(mill5$ = fx_two, MAT_DRL@, MAT_M1PRIME@)
        p_make_view_from_vector(tool_axial_vector_x, tool_axial_vector_y, tool_axial_vector_z)
        drl_m1$ = mteq(m1_prime)
        p_eulers(euler_axis1, euler_axis2, euler_axis3, !alpha, !beta, !gamma, result1)
        p_process_coordinate_data
        if cutpos$ >= FIVE@,
            if sec_start_sign <> ZERO@,
                p_choose_rotary_solution(init_rot_soln)
    gcode$ = fsg(fr$ = fx_n_two, fx_zero, fx_one)
GMT+8, 2026-11-5 16:11
