MiddleButtonJH v1.9.1
Mouse middle-button utility for Mastercam.
[ What's New in v1.9.1 ]
1. Single-click Select All for supported input fields
- Clicking a supported numeric or text input field in Mastercam once will automatically select the entire current value.
- You can immediately type a new value without double-clicking first.
2. Normal editing behavior is preserved
- Clicking the same focused input field again allows normal caret positioning.
- Mouse drag selection for partial text selection remains available.
3. Disabled by default
- The new feature is OFF by default.
- Enable the following option in the settings window:
"Select all on first input click"
4. Existing features are preserved
- Middle-button confirmation
- Mastercam-only mouse wheel speed
- Mouse side-button confirmation
- Keyboard confirmation functions
- Existing user settings
All existing v1.9.0 behavior remains unchanged.
[ Supported Areas ]
The feature currently supports verified standard Mastercam input fields.
Examples:
- Tool parameters
- Linking parameters
- Entry / Exit parameters
- Depth / Side machining parameters
- Filter parameters
- Other standard numeric input fields
[ Currently Unsupported ]
Some Mastercam custom input controls are not supported yet.
Example:
- Some fields in Tool Creation / Tool Definition
These controls use a different UI structure from standard Windows Edit controls,
so they are intentionally excluded from this release for stability.
[ Installation ]
Close Mastercam before updating.
Replace the existing MiddleButtonJH files with the v1.9.1 files,
then restart Mastercam.
Your existing settings.ini can be kept and reused.
Version: 1.9.1
Mastercam 鼠标中键辅助插件。
[ v1.9.1 主要更新 ]
1. 新增“单击输入框时全选内容”功能
- 在 Mastercam 中,单击支持的数字或文字输入框一次,即可自动全选当前内容。
- 无需再双击,可以直接输入新的数值。
2. 保留正常编辑操作
- 已经获得焦点的同一个输入框再次单击时,可以正常移动光标位置。
- 鼠标拖动进行部分文字选择的功能保持不变。
3. 新功能默认关闭
- 该功能默认处于关闭状态。
- 可在设置窗口中启用:
“单击输入框时全选内容”
4. 保留现有功能
- 鼠标中键确认功能
- 仅在 Mastercam 中生效的滚轮速度
- 鼠标侧键确认功能
- 键盘确认功能
- 原有用户设置
v1.9.0 的现有功能保持不变。
[ 支持范围 ]
目前支持已经验证过的 Mastercam 常规输入框。
例如:
- 刀具条件
- Linking 参数
- 进刀 / 退刀参数
- 深度 / 侧面加工参数
- 过滤参数
- 其他常规数字输入框
[ 当前不支持 ]
部分 Mastercam 自定义输入控件目前暂不支持。
例如:
- 刀具创建 / 刀具定义界面中的部分输入框
这些控件的 UI 结构与标准 Windows Edit 控件不同,
为了保证稳定性,本版本暂不支持。
[ 安装方法 ]
更新前请先关闭 Mastercam。
将现有 MiddleButtonJH 文件替换为 v1.9.1 文件,
然后重新启动 Mastercam。
原有 settings.ini 可以继续保留并使用。
Version: 1.9.1
v1.9.1.zip
(290.8 KB, 下载次数: 54)
