查看: 15|回复: 1
[分享] 第一个二次开发案例:根据体的面分割体
发表于 1 小时前 | 显示全部楼层 |阅读模式
第一个二次开发案例:根据体的面分割体
开发工具,NX2306,VS2019
步骤:
1.设计ui,选择面,SelectMode设定为single,一次选一个面
2.对生成的CPP,HPP文件进行代码补充,在int NX10::apply_cb() 回调方法中添加业务代码
 楼主| 发表于 1 小时前 | 显示全部楼层
        int errorCode = 0;
        try
                //获取选择对象
                vector<TaggedObject*> selObjs = faceSelect->GetSelectedObjects();
                int count = selObjs.size();
                int not_face_count = 0;
                int faceType = 0;
                //遍历面
                for (auto i : selObjs) {
                        tag_t t = i->Tag();
                        UF_MODL_ask_face_type(t, &faceType);
                        //只处理平面
                        if (faceType == UF_MODL_PLANAR_FACE) {
                                //创建切割平面
                                tag_t object_tags[3] = { t,NULL_TAG,NULL_TAG };
                                int point_select[3] = { 0, 0,0 };
                                int dp_n = 0;
                                tag_t dplane_tag[2] = { NULL_TAG,NULL_TAG };
                                char* angle_str = "0";
                                char* offset_str = "0";
                                UF_MODL_create_relative_dplane(1,
                                        object_tags,
                                        point_select,
                                        1,
                                        NULL,
                                        angle_str,
                                        offset_str,
                                        &dp_n,
                                        dplane_tag);
                                //获取切割平面特征 tag
                                int n_eids = 0;
                                tag_t* eids;
                                int ret = UF_MODL_ask_feat_object(dplane_tag[0], &n_eids, &eids);
                                tag_t splitPlane = NULL_TAG;
                                if (0 == ret && n_eids>0&& eids != NULL) {
                                        splitPlane = *eids;
                                tag_t bodies = NULL_TAG;
                                //获取面所在体 、颜色
                                UF_MODL_ask_face_body(t, &bodies);
                                int color;
                                UF_OBJ_disp_props_t disp_props;
                                UF_OBJ_ask_display_properties(t, &disp_props);
                                int color_id = disp_props.color;  // 这就是体的颜色 ID
                                char msg[256];
                                sprintf(msg, "%d", color_id);
                                uc1601(msg, 1);
                                //分割面
                                tag_t* split_bodies;
                                int spliN = 0;
                                tag_t bodies2[1] = { bodies };
                                UF_MODL_split_body(1, bodies2, splitPlane, &spliN, &split_bodies);
                                for (int i = 0;i < spliN;i++) {
                                        UF_OBJ_set_color(split_bodies[i], color_id);
                        else {
                                uc1601("选择非平面不处理", 1);
        catch (exception& ex)
                //---- Enter your exception handling code here -----
                errorCode = 1;
                NX10::theUI->NXMessageBox()->Show("Block Styler", NXOpen::NXMessageBox:ialogTypeError, ex.what());
        return errorCode;
GMT+8, 2026-11-20 19:16
