楼主: ....与昂°
[已回复] MasterCAM发那科BC零点偏置后处理,怎么解决B轴旋转方向是反的。求大神解决
发表于 2025-7-23 14:45:06 | 显示全部楼层
找到
#Primary axis angle description (in machine base terms)
#With nutating (mtype 3-5) the nutating axis must be the XY plane
rotaxis1$ = vecy  #Zero
rotdir1$  = vecx  #Direction
改为
rotdir1$  = -vecx  #Direction
xinruyu369@126.com
发表于 2025-7-23 15:56:42 | 显示全部楼层
你自己看看
 楼主| 发表于 2025-7-24 15:29:42 | 显示全部楼层
xinruyu369 发表于 2025-7-23 14:45
找到
#With nutating (mtype 3-5) the nutating ...
head_is_sec  : 1     #Set with mtype 1 and 4 to indicate head is on secondary
#Preferred setup is pri. zero matches sec. zero/direction
#Zero machine and determine the planes perp. to axis rotations
#These plane combinations are valid:
#Primary plane   XY   XZ   YZ
#Secondary or    XZ   XY   XY
#Secondary       YZ   YZ   XZ
rotaxis1$ = vecx  #Zero
rotdir1$  = -vecy  #Direction
#Secondary axis angle description (in machine base terms)
#With nutating (mtype 3-5) the nutating axis and this plane normal
#are aligned to calculate the secondary angle
rotaxis2$ = vecz  #Zero
rotdir2$  = -vecx  #Direction
我改好,程序出出来正确的是B-90,可这个后处理出来还是B90
发表于 2025-7-24 19:52:07 | 显示全部楼层
发出来让人帮改就行
发表于 2025-7-25 10:47:53 | 显示全部楼层
共同学习
发表于 2025-10-4 22:24:22 来自手机 | 显示全部楼层
机床定义里面顺逆时针
GMT+8, 2026-11-5 19:19
