查看: 1114|回复: 4
[分享] 分享几个WorkNC隐藏功能
发表于 2025-9-23 10:29:45 | 显示全部楼层 |阅读模式
WNC_MENU_GLOBAL_ROUGH_VAR_ZSTEP=ON
WNC_MENU_OPTFIN_TANG_EXT=on
WNC_MENU_HVR_VIEW=on
WNC_USE_TESTUSI=on
WNC_MENU_ACTIVATION_TOLERANCE=on
WNC_ACTIVATION_TOLERANCE=0.003
CLOSE_CONT=on
WNC_MENU_USER_DEFINED_STOCK=on
WNC_MENU_MIN_RETRACT=on
WNC_MENU_PROTOTYPE_ZLFV18=on
WNC_MENU_ALLOW_ZERO_COLCHK_CLEARANCE=on
WNC_REMACHINING_ROUGH=on
WNC_LINK_STEP=on
WNC_MENU_EXEC_MORE=on
WNC_MENU_CUTTER_ASSIGN=on
WNC_MENU_REPOST_AFTER_HOLDER_MODIF=ask
WNC_MENU_NO_STRATEGY_TOOLTIPS=off
WNC_MENU_HVR_GUIDE_CURVE=on
WNC_MENU_NEW_WZ_5AXIS=on
WNC_SMOOTH3D=on
WNC_SMOOTH_PARAM=0.1 5
WNC_MENU_ALLOW_TROCHOID_NONE=on
WNC_MENU_ALLOW_5AXIS_COMP_PP=ON
WNC_MENU_PP_COMP_CUTTER_WARN = ON
WNC_3TO5AXIS_ALLTOOLS=1
WNC_3TO5AXIS_ALLTYPES=1
WNC_3TO5AXIS_ALLPARAMS=1
WNC_MENU_ORBIT=on
WNC_MULTI_THREAD=2
 楼主| 发表于 2025-9-24 17:21:23 | 显示全部楼层
还可以,支持一边计算一边编程,这样快。不要等计算完成在编下一个,这样就慢
发表于 2025-9-23 13:32:41 | 显示全部楼层
WN好用吗?
发表于 2025-9-23 15:40:19 | 显示全部楼层
计算速度快吗?
禁止发言
发表于 2025-9-24 07:55:08 | 显示全部楼层
提示: 作者被禁止或删除 内容自动屏蔽
发表于 2025-12-6 19:15:03 来自手机 | 显示全部楼层
Thank you for sharing
GMT+8, 2026-10-17 23:23
