查看: 708|回复: 3
[求助] 宏录制问题
发表于 2025-10-16 14:17:41 | 显示全部楼层 |阅读模式
我录制了一个变化颜色的快捷键,因为录制时候使用工作图层3
使用时候我想变化一个在工作图层为5工件的颜色
问题来了:使用的时候之后他会自动把工件移动到3层《宏录制时候使用的图层》
怎么搞成在使用的时候不会动图层
宏记事本打开
NX 10.0.0.24
Macro File: D:\aaa\UG\H\毛坯颜色.macro
Macro Version 7.50
Macro List Language and Codeset: simpl_chinese 13
Created by Administrator on Thu Oct 16 14:08:30 2025
Part Name Display Style: $FILENAME
Selection Parameters 1 2 0.229167 1
Display Parameters 1.000000 11.958333 7.218750 -1.000000 -0.603659 1.000000 0.603659
RESET
MENU, 0, UG_EDIT_OBJECT_DISPLAY UG_GATEWAY_MAIN_MENUBAR < J> ## !
DIALOG_BEGIN "Edit Object Display" 5021 ! DA2
  BEG_ITEM  0 (1 BTAB 5021) = 1  !
  BEG_ITEM  3 (1 INTE 5021) = 3  ! Layer
  BEG_ITEM  5 (1 CTOL 5021) = -1  !
  BEG_ITEM  6 (1 OPTM 5021) = 1  ! Solid
  BEG_ITEM  7 (1 OPTM 5021) = 1  ! 0.13 mm
  BEG_ITEM 11 (1 SCAL 5021) = 0  !
  BEG_ITEM 12 (1 BOOL 5021) = 0  ! Partially Shaded
  BEG_ITEM 13 (1 BOOL 5021) = 0  ! Face Analysis
  BEG_ITEM 16 (1 BOOL 5021) = 0  ! Show Poles
  BEG_ITEM 17 (1 BOOL 5021) = 0  ! Show Knots
  BEG_ITEM 18 (1 INTE 5021) = 0  ! U
  BEG_ITEM 19 (1 INTE 5021) = 0  ! V
  BEG_ITEM 22 (1 OPTM 5021) = 0  ! ##15No Change
  BEG_ITEM 23 (0 INTE 5021) = 0  ! Display Sample
  BEG_ITEM 26 (1 BOOL 5021) = 1  ! Apply to All Faces of Selected Body
  BEG_ITEM 27 (0 BOOL 5021) = 0  ! Apply Changes to Owning Part
  BEG_ITEM 34 (1 BOOL 5021) = 1  ! Needle
  BEG_ITEM 35 (1 CTOL 5021) = 131  !
  BEG_ITEM 37 (1 BOOL 5021) = 1  ! Cap
  BEG_ITEM 38 (1 CTOL 5021) = 131  !
  BEG_ITEM 40 (1 BOOL 5021) = 1  ! Needle
  BEG_ITEM 41 (1 CTOL 5021) = 84  !
  BEG_ITEM 43 (1 BOOL 5021) = 1  ! Cap
  BEG_ITEM 44 (1 CTOL 5021) = 84  !
  BEG_ITEM 46 (1 BOOL 5021) = 1  ! Needle
  BEG_ITEM 47 (1 CTOL 5021) = 184  !
  BEG_ITEM 49 (1 BOOL 5021) = 1  ! Cap
  BEG_ITEM 50 (1 CTOL 5021) = 184  !
  BEG_ITEM 52 (1 BOOL 5021) = 1  ! Needle
  BEG_ITEM 53 (1 CTOL 5021) = 117  !
  BEG_ITEM 55 (1 BOOL 5021) = 1  ! Cap
  BEG_ITEM 56 (1 CTOL 5021) = 117  !
  BEG_ITEM 61 (1 OPTM 5021) = 1  ! ##03Solid
  BEG_ITEM 63 (1 OPTM 5021) = 1  ! ##04Solid
  BEG_ITEM 69 (1 CTOL 5021) = 161  !
  BEG_ITEM 70 (1 OPTM 5021) = 1  ! ##05Solid
  BEG_ITEM 71 (1 BOOL 5021) = 1  ! Needle
  BEG_ITEM 72 (1 CTOL 5021) = 159  !
  BEG_ITEM 73 (1 OPTM 5021) = 1  ! ##06Solid
  BEG_ITEM 74 (1 BOOL 5021) = 1  ! Cap
  BEG_ITEM 75 (1 CTOL 5021) = 120  !
  BEG_ITEM 76 (1 OPTM 5021) = 1  ! ##07Solid
  BEG_ITEM 82 (1 CTOL 5021) = 99  !
  BEG_ITEM 83 (1 OPTM 5021) = 1  ! ##08Solid
  BEG_ITEM 84 (1 BOOL 5021) = 1  ! Cap
  BEG_ITEM 85 (1 CTOL 5021) = 160  !
  BEG_ITEM 86 (1 OPTM 5021) = 1  ! ##09Solid
  BEG_ITEM 92 (1 CTOL 5021) = 161  !
  BEG_ITEM 93 (1 OPTM 5021) = 1  ! ##10Solid
  BEG_ITEM 94 (1 BOOL 5021) = 1  ! Needle
  BEG_ITEM 95 (1 CTOL 5021) = 176  !
  BEG_ITEM 96 (1 OPTM 5021) = 1  ! ##11Solid
  BEG_ITEM 97 (1 BOOL 5021) = 1  ! Cap
  BEG_ITEM 98 (1 CTOL 5021) = 117  !
  BEG_ITEM 99 (1 OPTM 5021) = 1  ! ##12Solid
  BEG_ITEM 105 (1 CTOL 5021) = 159  !
  BEG_ITEM 106 (1 OPTM 5021) = 1  ! ##13Solid
  BEG_ITEM 108 (1 CTOL 5021) = 161  !
  BEG_ITEM 114 (1 CTOL 5021) = 140  !
  BEG_ITEM 115 (1 OPTM 5021) = 1  ! ##14Solid
  EVENT DRAG 0 5021, 11, 0, 0, 0!
  ASK_ITEM 11 (1 SCAL 5021) = 10  !
  ASK_ITEM 26 (1 BOOL 5021) = 1  ! Apply to All Faces of Selected Body
  ASK_ITEM 27 (0 BOOL 5021) = 0  ! Apply Changes to Owning Part
  EVENT VALUE_CHANGED 0 5021, 11, 0, 0, 0!
  ASK_ITEM 11 (1 SCAL 5021) = 20  !
  ASK_ITEM 11 (1 SCAL 5021) = 30  !
  ASK_ITEM 11 (1 SCAL 5021) = 40  !
  ASK_ITEM 11 (1 SCAL 5021) = 50  !
  END_ITEM  0 (1 BTAB 5021) = 1  !
  END_ITEM  3 (1 INTE 5021) = 3  ! Layer
  END_ITEM  5 (1 CTOL 5021) = 125  !
  END_ITEM  6 (1 OPTM 5021) = 1  ! Solid
  END_ITEM  7 (1 OPTM 5021) = 1  ! 0.13 mm
  END_ITEM 11 (1 SCAL 5021) = 50  !
  END_ITEM 12 (1 BOOL 5021) = 0  ! Partially Shaded
  END_ITEM 13 (1 BOOL 5021) = 0  ! Face Analysis
  END_ITEM 16 (1 BOOL 5021) = 0  ! Show Poles
  END_ITEM 17 (1 BOOL 5021) = 0  ! Show Knots
  END_ITEM 18 (1 INTE 5021) = 0  ! U
  END_ITEM 19 (1 INTE 5021) = 0  ! V
  END_ITEM 22 (1 OPTM 5021) = 0  ! ##15No Change
  END_ITEM 23 (0 INTE 5021) = 0  ! Display Sample
  END_ITEM 26 (1 BOOL 5021) = 1  ! Apply to All Faces of Selected Body
  END_ITEM 27 (0 BOOL 5021) = 0  ! Apply Changes to Owning Part
  END_ITEM 34 (1 BOOL 5021) = 1  ! Needle
  END_ITEM 35 (1 CTOL 5021) = 131  !
  END_ITEM 37 (1 BOOL 5021) = 1  ! Cap
  END_ITEM 38 (1 CTOL 5021) = 131  !
  END_ITEM 40 (1 BOOL 5021) = 1  ! Needle
  END_ITEM 41 (1 CTOL 5021) = 84  !
  END_ITEM 43 (1 BOOL 5021) = 1  ! Cap
  END_ITEM 44 (1 CTOL 5021) = 84  !
  END_ITEM 46 (1 BOOL 5021) = 1  ! Needle
  END_ITEM 47 (1 CTOL 5021) = 184  !
  END_ITEM 49 (1 BOOL 5021) = 1  ! Cap
  END_ITEM 50 (1 CTOL 5021) = 184  !
  END_ITEM 52 (1 BOOL 5021) = 1  ! Needle
  END_ITEM 53 (1 CTOL 5021) = 117  !
  END_ITEM 55 (1 BOOL 5021) = 1  ! Cap
  END_ITEM 56 (1 CTOL 5021) = 117  !
  END_ITEM 61 (1 OPTM 5021) = 1  ! ##03Solid
  END_ITEM 63 (1 OPTM 5021) = 1  ! ##04Solid
  END_ITEM 69 (1 CTOL 5021) = 161  !
  END_ITEM 70 (1 OPTM 5021) = 1  ! ##05Solid
  END_ITEM 71 (1 BOOL 5021) = 1  ! Needle
  END_ITEM 72 (1 CTOL 5021) = 159  !
  END_ITEM 73 (1 OPTM 5021) = 1  ! ##06Solid
  END_ITEM 74 (1 BOOL 5021) = 1  ! Cap
  END_ITEM 75 (1 CTOL 5021) = 120  !
  END_ITEM 76 (1 OPTM 5021) = 1  ! ##07Solid
  END_ITEM 82 (1 CTOL 5021) = 99  !
  END_ITEM 83 (1 OPTM 5021) = 1  ! ##08Solid
  END_ITEM 84 (1 BOOL 5021) = 1  ! Cap
  END_ITEM 85 (1 CTOL 5021) = 160  !
  END_ITEM 86 (1 OPTM 5021) = 1  ! ##09Solid
  END_ITEM 92 (1 CTOL 5021) = 161  !
  END_ITEM 93 (1 OPTM 5021) = 1  ! ##10Solid
  END_ITEM 94 (1 BOOL 5021) = 1  ! Needle
  END_ITEM 95 (1 CTOL 5021) = 176  !
  END_ITEM 96 (1 OPTM 5021) = 1  ! ##11Solid
  END_ITEM 97 (1 BOOL 5021) = 1  ! Cap
  END_ITEM 98 (1 CTOL 5021) = 117  !
  END_ITEM 99 (1 OPTM 5021) = 1  ! ##12Solid
  END_ITEM 105 (1 CTOL 5021) = 159  !
  END_ITEM 106 (1 OPTM 5021) = 1  ! ##13Solid
  END_ITEM 108 (1 CTOL 5021) = 161  !
  END_ITEM 114 (1 CTOL 5021) = 140  !
  END_ITEM 115 (1 OPTM 5021) = 1  ! ##14Solid
DIALOG_END -2, 0 ! Edit Object Display: OK
FOCUS CHANGE IN 1
 楼主| 发表于 2025-10-16 15:05:09 | 显示全部楼层
已解决
发表于 2025-12-14 16:16:08 | 显示全部楼层
如何解决的?
 楼主| 发表于 2026-3-30 18:46:24 | 显示全部楼层
换了个方法,先点命令在选体就会移动图层,换成先选体再命令就不会
GMT+8, 2026-10-25 12:56
