查看: 657|回复: 5
[求助] 在哪里添加什么代码,可使工件名跟文件名不一致,终止后处理
奖 32 G币 回复本帖可获得 2 G币奖励! 每人限 1 次
发表于 2025-10-20 22:15:28 | 显示全部楼层 |阅读模式
proc MOM_start_of_program { } {
  global mom_logname mom_date is_from
  global mom_coolant_status mom_cutcom_status
  global mom_clamp_status mom_cycle_status
  global mom_spindle_status mom_cutcom_plane pb_start_of_program_flag
  global mom_cutcom_adjust_register mom_tool_adjust_register
  global mom_tool_length_adjust_register mom_length_comp_register
  global mom_flush_register mom_wire_cutcom_adjust_register
  global mom_wire_cutcom_status
    set pb_start_of_program_flag 0
    set mom_coolant_status UNDEFINED
    set mom_cutcom_status  UNDEFINED
    set mom_clamp_status   UNDEFINED
    set mom_cycle_status   UNDEFINED
    set mom_spindle_status UNDEFINED
    set mom_cutcom_plane   UNDEFINED
    set mom_wire_cutcom_status  UNDEFINED
    catch {unset mom_cutcom_adjust_register}
    catch {unset mom_tool_adjust_register}
    catch {unset mom_tool_length_adjust_register}
    catch {unset mom_length_comp_register}
    catch {unset mom_flush_register}
    catch {unset mom_wire_cutcom_adjust_register}
    set is_from ""
        catch { OPEN_files } ; #open warning and listing files
    LIST_FILE_HEADER ; #list header in commentary listing
  global mom_sys_post_initialized
  if { $mom_sys_post_initialized > 1 } { return }
   # Load parameters for alternate output units
    PB_load_alternate_unit_settings
    rename PB_load_alternate_unit_settings ""
安全获取程序名和工件名(原始值)[color=var(--md-box-body-color,var(--md-box-global-text-color))]set raw_prog_name ""
set raw_part_name ""
if { [catch { set prog_name $mom_program_name }] } { set prog_name "UNKNOWN_PROG" }
if { [catch { set part_name $mom_part_name }] } { set part_name "UNKNOWN_PART" }
标准化名称[color=var(--md-box-body-color,var(--md-box-global-text-color))]set prog_name [regsub -all {[^A-Z0-9]} [string trim [string toupper $prog_name]] ""]
set part_name [regsub -all {[^A-Z0-9]} [string trim [string toupper $part_name]] ""]
调试输出,确认原始值和标准化后的值[color=var(--md-box-body-color,var(--md-box-global-text-color))]MOM_output_literal "(调试:原始程序名 =原始工件名raw_part_name)\n"
MOM_output_literal "(调试:处理后程序名 =工件名part_name)\n"
修改条件判断,比较原始值(如果希望如此)或者保持比较标准化后的值,但确保标准化过程正确[color=var(--md-box-body-color,var(--md-box-global-text-color))]if { [string compare $prog_name [color=red !important]part\_name] != 0 } { MOM\_output\_literal "(错误:程序名称与工件名称不符!原始程序名:raw_prog_name,原始工件名:$raw_part_name)\n"
MOM_abort "后处理终止:程序名与工件名必须一致"
[color=var(--md-box-body-color,var(--md-box-global-text-color))]自己加这段没反应
发表于 2025-10-21 08:25:24 | 显示全部楼层
回帖奖励 +2 G币
你看看UG爱好者小梁  里面可能会有的
发表于 2025-10-27 08:03:38 | 显示全部楼层
你看看UG爱好者小梁 里面可能会有的
发表于 2025-10-28 19:50:42 | 显示全部楼层
回帖奖励 +2 G币
有什么意义?
发表于 2025-11-11 09:37:25 | 显示全部楼层
回帖奖励 +2 G币
没有搞懂
发表于 2025-11-14 15:55:27 | 显示全部楼层
这是怕调错程序吗
GMT+8, 2026-11-18 20:46
