查看: 335|回复: 1
[分享] 创建带长方体 源程序分享
发表于 2026-10-10 11:53:54 | 显示全部楼层 |阅读模式
'创建新零件
        Dim newPart As Part = Nothing
        Dim partName As String = InputBox("请输入新零件名称(不带扩展名):", "新建零件", "block_part")
        If partName Is Nothing OrElse partName = "" Then Return
        Try
            ' 创建新部件文件,使用毫米单位
            newPart = theSession.Parts.NewBaseDisplay(partName & ".prt", Part.Units.Millimeters)
            If newPart Is Nothing Then
                theUI.NXMessageBox.Show("错误", NXMessageBox.DialogType.Error, "创建新零件失败!")
                Return
            End If
            Dim workPart As Part = newPart
            ' 获取用户输入的长宽高(使用自定义对话框,3个独立输入框)
            Dim dialog As New BlockInputDialog()
            Dim result As DialogResult = dialog.ShowDialog()
            If result <> DialogResult.OK OrElse Not dialog.DialogOK Then
                Return
            End If
            Dim length As Double = dialog.Length
            Dim width As Double = dialog.Width
            Dim height As Double = dialog.Height
            ' 开始
            Dim nullFeatures_Feature As Features.Feature = Nothing
            Dim blockFeatureBuilder As Features.BlockFeatureBuilder
            blockFeatureBuilder = workPart.Features.CreateBlockFeatureBuilder(nullFeatures_Feature)
            ' 设置长方体类型为原点和边长
            blockFeatureBuilder.Type = Features.BlockFeatureBuilder.Types.OriginAndEdgeLengths
            ' 设置原点,使长方体中心与工作坐标系原点重合
            ' 长方体的一个角点为 (-length/2, -width/2, -height/2),这样中心就在 (0, 0, 0)
            Dim origin As Point3d = New Point3d(-length/2, -width/2, -height/2)
            blockFeatureBuilder.SetOriginAndLengths(origin, length, width, height)
            ' 应用并生成长方体
            Dim nXObject1 As NXObject
            nXObject1 = blockFeatureBuilder.Commit()
            blockFeatureBuilder.Destroy()
发表于 2026-10-22 14:32:23 | 显示全部楼层
谢谢分享66
GMT+8, 2026-11-24 18:11
