查看: 787|回复: 3
[分享] 手把手教你制作UG四五轴宏联动后处理(四)
发表于 2025-12-27 03:00:50 | 显示全部楼层 |阅读模式
  (20).将"初始移动"事件下的G0 G90 G(54~59) X Y A C S M3行复制到"第一次移动"事件下的PB_CMD_calc_g54行下面。
  (21).在"初始移动"事件下的G0 G90 G(54~59) X Y A C S M3行下面添加G0 G90 G(54~59) 文本元素1 文本元素2 A C S M3行,
       将文本元素1内容改成X$sx,将文本元素2内容改成Y$sy,
       添加输出条件PB__CMD_check_block_initial_move_1,编辑TCL代码如下:
       global dpp_path_type
       global e1 e2 e3 d1 d2 d3 vx vy vz rad_a rad_c
       global w1 w2 w3 s s1 s2 s3 s4 sx sy sz
       global mom_pos mom_out_angle_pos
       if {![string compare "5X" $dpp_path_type]} {
         set rad_a [expr $mom_out_angle_pos(0)*0.01745329252]
         set rad_c [expr $mom_out_angle_pos(1)*0.01745329252]
         #******************计算刀尖跟随Xrtcp**********************
         set e1 [expr cos($rad_c)-1.0]
         set e2 [expr sin($rad_c)]
         #变量d1,d2精确到小数点后6位,变量vx精确到小数点后3位
         set d1 [expr round($e1*1000000.0)/1000000.0]
         set d2 [expr round($e2*1000000.0)/1000000.0]
         set vx [expr round($mom_pos(0)*1000.0)/1000.0]
         #将变量d1转换成字符串s1,并且去除末尾多余0
         set w1 [format "%.6f" $d1]
         if {![string compare "-1.000000" $w1]} {
           set s1 "-#101"
         } elseif {![string compare "1.000000" $w1]} {
             set s1 "#101"
           } else {
               if {[string index $w1 end-0] == "0"} {
                 if {[string index $w1 end-1] == "0"} {
                   if {[string index $w1 end-2] == "0"} {
                     if {[string index $w1 end-3] == "0"} {
                       if {[string index $w1 end-4] == "0"} {
                         if {[string index $w1 end-5] == "0"} {
                           set w1 [format "%d." [expr round($d1)]]
                         } else {
                             set w1 [format "%.1f" $d1]
                       } else {
                           set w1 [format "%.2f" $d1]
                     } else {
                         set w1 [format "%.3f" $d1]
                   } else {
                       set w1 [format "%.4f" $d1]
                 } else {
                     set w1 [format "%.5f" $d1]
              if {$d1 != 0.0} {
                set s1 [format "%s*#101" $w1]
              } else {
                  set s1 "NONE"
         #将变量d2转换成字符串s2,并且去除末尾多余0
         set w2 [format "%.6f" $d2]
         if {![string compare "-1.000000" $w2]} {
           set s2 "-#102"
         } elseif {![string compare "1.000000" $w2]} {
             set s2 "+#102"
           } else {
               if {[string index $w2 end-0] == "0"} {
                 if {[string index $w2 end-1] == "0"} {
                   if {[string index $w2 end-2] == "0"} {
                     if {[string index $w2 end-3] == "0"} {
                       if {[string index $w2 end-4] == "0"} {
                         if {[string index $w2 end-5] == "0"} {
                           set w2 [format "%d." [expr round($d2)]]
                         } else {
                             set w2 [format "%.1f" $d2]
                       } else {
                           set w2 [format "%.2f" $d2]
                     } else {
                         set w2 [format "%.3f" $d2]
                   } else {
                       set w2 [format "%.4f" $d2]
                 } else {
                     set w2 [format "%.5f" $d2]
              if {$d2 > 0.0} {
                set s2 [format "+%s*#102" $w2]
              } elseif {$d2 < 0.0} {
                  set s2 [format "%s*#102" $w2]
                } else {
                    set s2 "NONE"
            #将变量vx转换成字符串s4,并且去除末尾多余0
            set w4 [format "%.3f" $vx]
            if {[string index $w4 end-0] == "0"} {
              if {[string index $w4 end-1] == "0"} {
                if {[string index $w4 end-2] == "0"} {
                  set w4 [format "%d." [expr round($vx)]]
                } else {
                    set w4 [format "%.1f" $vx]
              } else {
                  set w4 [format "%.2f" $vx]
          if {$vx > 0.0} {
            set s4 [format "+%s" $w4]
          } elseif {$vx < 0.0} {
              set s4 [format "%s" $w4]
           } else {
               set s4 "NONE"
         #格式化字符串s,保存到变量sx中,用于输出
         if {[string compare "NONE" $s1] && ![string compare "NONE" $s2]} {
           set s $s1
         } elseif {![string compare "NONE" $s1] && [string compare "NONE" $s2]} {
             set s $s2
           } elseif {[string compare "NONE" $s1] && [string compare "NONE" $s2]} {
               set s [format "%s%s" $s1 $s2]
             } else {
                 set s "NONE"
        if {[string compare "NONE" $s] && [string compare "NONE" $s4]} {
          set sx [format "\[%s%s\]" $s $s4]
        } elseif {![string compare "NONE" $s] && [string compare "NONE" $s4]} {
            set sx $s4
          } elseif {[string compare "NONE" $s] && ![string compare "NONE" $s4]} {
              set sx [format "\[%s\]" $s]
            } else {
                set sx "0."
       #******************计算刀尖跟随Yrtcp***************************
       set e1 [expr cos($rad_a)*cos($rad_c)-1.0]
       set e2 [expr -1.0*cos($rad_a)*sin($rad_c)]
       set e3 [expr sin($rad_a)]
       set d3 [expr round($e3*1000000.0)/1000000.0]
       set vy [expr round($mom_pos(1)*10000.0)/10000.0]
          set s1 "-#102"
           set s1 "#102"
         } else {
                       } else {
                     } else {
                   } else {
                 } else {
               } else {
             if {$d1 != 0.0} {
               set s1 [format "%s*#102" $w1]
             } else {
                 set s1 "NONE"
             set s2 "-#101"
               set s2 "+#101"
             } else {
                           } else {
                         } else {
                       } else {
                     } else {
                   } else {
                 if {$d2 > 0.0} {
                   set s2 [format "+%s*#101" $w2]
                     set s2 [format "%s*#101" $w2]
                   } else {
                       set s2 "NONE"
未完待续。。。。。
发表于 2026-1-2 15:55:21 | 显示全部楼层
感谢大佬
35
发表于 2026-3-30 13:28:04 来自手机 | 显示全部楼层
感谢大佬分享!大佬牛掰!👍👍👍
发表于 2026-4-18 10:40:14 | 显示全部楼层
GMT+8, 2026-11-18 20:31
