查看: 706|回复: 8
[分享] 手把手教你制作UG四五轴宏联动后处理(五)
发表于 2025-12-27 03:34:45 | 显示全部楼层 |阅读模式
set w3 [format "%.6f" $d3]
              if {![string compare "-1.000000" $w3]} {
                set s3 "-#103"
              } elseif {![string compare "1.000000" $w3]} {
                  set s3 "+#103"
                } else {
                    if {[string index $w3 end-0] == "0"} {
                      if {[string index $w3 end-1] == "0"} {
                        if {[string index $w3 end-2] == "0"} {
                          if {[string index $w3 end-3] == "0"} {
                            if {[string index $w3 end-4] == "0"} {
                              if {[string index $w3 end-5] == "0"} {
                                set w3 [format "%d." [expr round($d3)]]
                              } else {
                                  set w3 [format "%.1f" $d3]
                            } else {
                                set w3 [format "%.2f" $d3]
                          } else {
                              set w3 [format "%.3f" $d3]
                        } else {
                            set w3 [format "%.4f" $d3]
                      } else {
                          set w3 [format "%.5f" $d3]
                    if {$d3 > 0.0} {
                      set s3 [format "+%s*#103" $w3]
                    } elseif {$d3 < 0.0} {
                        set s3 [format "%s*#103" $w3]
                      } else {
                          set s3 "NONE"
                 set w4 [format "%.4f" $vy]
                 if {[string index $w4 end-0] == "0"} {
                   if {[string index $w4 end-1] == "0"} {
                     if {[string index $w4 end-2] == "0"} {
                       if {[string index $w4 end-3] == "0"} {
                         set w4 [format "%d." [expr round($vy)]]
                       } else {
                           set w4 [format "%.1f" $vy]
                     } else {
                         set w4 [format "%.2f" $vy]
                   } else {
                       set w4 [format "%.3f" $vy]
                 if {$vy > 0.0} {
                   set s4 [format "+%s" $w4]
                 } elseif {$vy < 0.0} {
                     set s4 [format "%s" $w4]
                   } else {
                       set s4 "NONE"
                if {[string compare "NONE" $s1] && [string compare "NONE" $s2] && [string compare "NONE" $s3]} {
                  set s [format "%s%s%s" $s1 $s2 $s3]
                } elseif {[string compare "NONE" $s1] && ![string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
                    set s $s1
                  } elseif {![string compare "NONE" $s1] && [string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
                      set s $s2
                    } elseif {![string compare "NONE" $s1] && ![string compare "NONE" $s2] && [string compare "NONE" $s3]} {
                        set s $s3
                      } elseif {[string compare "NONE" $s1] && [string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
                          set s [format "%s%s" $s1 $s2]
                        } elseif {[string compare "NONE" $s1] && ![string compare "NONE" $s2] && [string compare "NONE" $s3]} {
                            set s [format "%s%s" $s1 $s3]
                          } elseif {![string compare "NONE" $s1] && [string compare "NONE" $s2] && [string compare "NONE" $s3]} {
                              set s [format "%s%s" $s2 $s3]
                           } else {
                               set s "NONE"
                if {[string compare "NONE" $s] && [string compare "NONE" $s4]} {
                   set sy [format "\[%s%s\]" $s $s4]
                } elseif {![string compare "NONE" $s] && [string compare "NONE" $s4]} {
                    set sy $s4
                  } elseif {[string compare "NONE" $s] && ![string compare "NONE" $s4]} {
                      set sy [format "\[%s\]" $s]
                    } else {
                        set sy "0."
         #******************计算刀尖跟随Zrtcp**********************************
         set e1 [expr sin($rad_a)*sin($rad_c)]
         set e2 [expr -1.0*sin($rad_a)*cos($rad_c)]
         set e3 [expr cos($rad_a)-1.0]
         set d1 [expr round($e1*1000000.0)/1000000.0]
         set d2 [expr round($e2*1000000.0)/1000000.0]
         set d3 [expr round($e3*1000000.0)/1000000.0]
         set vz [expr round($mom_pos(2)*10000.0)/10000.0]
         set w1 [format "%.6f" $d1]
         if {![string compare "-1.000000" $w1]} {
            set s1 "-#101"
         } elseif {![string compare "1.000000" $w1]} {
             set s1 "#101"
           } else {
               if {[string index $w1 end-0] == "0"} {
                 if {[string index $w1 end-1] == "0"} {
                   if {[string index $w1 end-2] == "0"} {
                     if {[string index $w1 end-3] == "0"} {
                       if {[string index $w1 end-4] == "0"} {
                         if {[string index $w1 end-5] == "0"} {
                            set w1 [format "%d." [expr round($d1)]]
                         } else {
                             set w1 [format "%.1f" $d1]
                       } else {
                           set w1 [format "%.2f" $d1]
                     } else {
                         set w1 [format "%.3f" $d1]
                   } else {
                       set w1 [format "%.4f" $d1]
                 } else {
                     set w1 [format "%.5f" $d1]
               if {$d1 != 0.0} {
                 set s1 [format "%s*#101" $w1]
               } else {
                   set s1 "NONE"
        set w2 [format "%.6f" $d2]
        if {![string compare "-1.000000" $w2]} {
          set s2 "-#102"
        } elseif {![string compare "1.000000" $w2]} {
            set s2 "+#102"
          } else {
              if {[string index $w2 end-0] == "0"} {
                if {[string index $w2 end-1] == "0"} {
                  if {[string index $w2 end-2] == "0"} {
                    if {[string index $w2 end-3] == "0"} {
                      if {[string index $w2 end-4] == "0"} {
                        if {[string index $w2 end-5] == "0"} {
                          set w2 [format "%d." [expr round($d2)]]
                        } else {
                            set w2 [format "%.1f" $d2]
                      } else {
                          set w2 [format "%.2f" $d2]
                    } else {
                        set w2 [format "%.3f" $d2]
                  } else {
                      set w2 [format "%.4f" $d2]
                } else {
                    set w2 [format "%.5f" $d2]
              if {$d2 > 0.0} {
                set s2 [format "+%s*#102" $w2]
              } elseif {$d2 < 0.0} {
                  set s2 [format "%s*#102" $w2]
                } else {
                    set s2 "NONE"
            set s3 "-#103"
             set s3 "+#103"
           } else {
                        } else {
                     } else {
                  } else {
                } else {
              } else {
            if {$d3 > 0.0} {
              } else {
                  set s3 "NONE"
未完待续。。。。
作者 南京标子
发表于 2025-12-27 10:09:00 来自手机 | 显示全部楼层
神仙留步,凡人可以退了
发表于 2025-12-27 10:26:18 来自手机 | 显示全部楼层
大佬,NB……
发表于 2025-12-28 17:45:11 | 显示全部楼层
直接把后处理分享出来研究下呗
发表于 2026-1-2 15:56:45 | 显示全部楼层
感谢大佬
35
发表于 2026-3-30 13:27:45 来自手机 | 显示全部楼层
感谢大佬分享!大佬牛掰!👍👍👍
发表于 2026-4-18 10:40:30 | 显示全部楼层
发表于 2026-4-19 20:21:54 | 显示全部楼层
感谢楼主无私分享,支持一下,非常实用的好资源!
发表于 2026-7-28 21:19:41 | 显示全部楼层
GMT+8, 2026-11-18 20:01
