查看: 677|回复: 5
[分享] 手把手教你制作UG四五轴宏联动后处理(六)
发表于 2025-12-28 02:27:31 | 显示全部楼层 |阅读模式
         set w4 [format "%.4f" $vz]
         if {[string index $w4 end-0] == "0"} {
           if {[string index $w4 end-1] == "0"} {
             if {[string index $w4 end-2] == "0"} {
               if {[string index $w4 end-3] == "0"} {
                 set w4 [format "%d." [expr round($vz)]]
               } else {
                   set w4 [format "%.1f" $vz]
             } else {
                 set w4 [format "%.2f" $vz]
           } else {
               set w4 [format "%.3f" $vz]
         if {$vz > 0.0} {
           set s4 [format "+%s" $w4]
         } elseif {$vz < 0.0} {
             set s4 [format "%s" $w4]
           } else {
               set s4 "NONE"
         if {[string compare "NONE" $s1] && [string compare "NONE" $s2] && [string compare "NONE" $s3]} {
           set s [format "%s%s%s" $s1 $s2 $s3]
         } elseif {[string compare "NONE" $s1] && ![string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
             set s $s1
           } elseif {![string compare "NONE" $s1] && [string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
               set s $s2
             } elseif {![string compare "NONE" $s1] && ![string compare "NONE" $s2] && [string compare "NONE" $s3]} {
                 set s $s3
               } elseif {[string compare "NONE" $s1] && [string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
                   set s [format "%s%s" $s1 $s2]
                 } elseif {[string compare "NONE" $s1] && ![string compare "NONE" $s2] && [string compare "NONE" $s3]} {
                     set s [format "%s%s" $s1 $s3]
                   } elseif {![string compare "NONE" $s1] && [string compare "NONE" $s2] && [string compare "NONE" $s3]} {
                       set s [format "%s%s" $s2 $s3]
                     } else {
                         set s "NONE"
          if {[string compare "NONE" $s] && [string compare "NONE" $s4]} {
             set sz [format "\[%s%s\]" $s $s4]
          } elseif {![string compare "NONE" $s] && [string compare "NONE" $s4]} {
              set sz $s4
            } elseif {[string compare "NONE" $s] && ![string compare "NONE" $s4]} {
                set sz [format "\[%s\]" $s]
              } else {
                  set sz "0."
          return 1
       return 0
       点击确定。
      (22).将"初始移动"事件下的G0 G90 G(54~59) 文本元素1 文本元素2 A C S M3行复制到"第一次移动"事件下的G0 G90 (54~59) X Y A C S M3行下面。
  (23).在"初始移动"事件下的G0 G90 G(54~59) 文本元素1 文本元素2 A C S M3行下面添加G43 Z H1 M8行,
       添加输出条件PB__CMD_check_block_initial_move2,编辑TCL代码如下:
       global dpp_path_type
       if {![string compare "3X" $dpp_path_type]} {
          return 1
       return 0
       点击确定。
  (24).将"初始移动"事件下的G43 Z H1 M8行复制到"第一次移动"事件下的G0 G90 (54~59) 文本元素1 文本元素2 X Y A C S M3行下面。
  (25).在"初始移动"事件下的G43 Z H1 M8行下面添加G43 文本元素 H1 M8行,将文本元素内容改为Z$sz,
       添加输出条件PB__CMD_check_block_initial_move3,编辑TCL代码如下:
       if {![string compare "5X" $dpp_path_type]} {
         return 1
       return 0
       点击确定。
  (26).将"初始移动"事件下的G43 文本元素 H1 M8行复制到"第一次移动"事件下的G43 Z H1 M8行下面。
7.在"程序和刀轨"选项卡中,选择左侧"运动"选项:
  (1).将"圆周移动"事件下的G17 G2 G90 X Y Z I J K F S行中的G17和S元素删除,将G2元素设置为强制输出,
      添加输出条件PB__CMD_check_block_circular_move,编辑TCL代码如下:
        return 1
      return 0
      点击确定。
  (2).将"线性移动"事件下的G41 G17 G1 G90 X Y Z A C F S D1 M3 M8行中的G17,S,M3,M8元素删除,
      添加输出条件PB__CMD_check_block_linear_move,编辑TCL代码如下:
        return 1
      return 0
      点击确定。
  (3).在"线性移动"事件下的G41 G1 G90 X Y Z A C F D1行下面添加G41 G1 G90 文本元素 A C F D1行,
      将文本元素内容改为X$sx Y$sy Z$sz,添加输出条件PB_CMD__check_block_linear_move_1,
      编辑TCL代码如下:
      global e1 e2 e3 d1 d2 d3 vx vy vz rad_a rad_c
      global w1 w2 w3 s s1 s2 s3 s4 sx sy sz
      global mom_pos mom_out_angle_pos
        set rad_a [expr $mom_out_angle_pos(0)*0.01745329252]
        set rad_c [expr $mom_out_angle_pos(1)*0.01745329252]
        #******************计算刀尖跟随Xrtcp**********************
        set e1 [expr cos($rad_c)-1.0]
        set e2 [expr sin($rad_c)]
        set d1 [expr round($e1*1000000.0)/1000000.0]
        set d2 [expr round($e2*1000000.0)/1000000.0]
        set vx [expr round($mom_pos(0)*10000.0)/10000.0]
        set w1 [format "%.6f" $d1]
        if {![string compare "-1.000000" $w1]} {
          set s1 "-#101"
        } elseif {![string compare "1.000000" $w1]} {
            set s1 "#101"
          } else {
              if {[string index $w1 end-0] == "0"} {
                if {[string index $w1 end-1] == "0"} {
                  if {[string index $w1 end-2] == "0"} {
                    if {[string index $w1 end-3] == "0"} {
                      if {[string index $w1 end-4] == "0"} {
                        if {[string index $w1 end-5] == "0"} {
                          set w1 [format "%d." [expr round($d1)]]
                        } else {
                            set w1 [format "%.1f" $d1]
                      } else {
                          set w1 [format "%.2f" $d1]
                    } else {
                        set w1 [format "%.3f" $d1]
                  } else {
                      set w1 [format "%.4f" $d1]
                } else {
                    set w1 [format "%.5f" $d1]
              if {$d1 != 0.0} {
                set s1 [format "%s*#101" $w1]
              } else {
                  set s1 "NONE"
         set w2 [format "%.6f" $d2]
         if {![string compare "-1.000000" $w2]} {
           set s2 "-#102"
         } elseif {![string compare "1.000000" $w2]} {
             set s2 "+#102"
           } else {
               if {[string index $w2 end-0] == "0"} {
                 if {[string index $w2 end-1] == "0"} {
                   if {[string index $w2 end-2] == "0"} {
                     if {[string index $w2 end-3] == "0"} {
                       if {[string index $w2 end-4] == "0"} {
                         if {[string index $w2 end-5] == "0"} {
                           set w2 [format "%d." [expr round($d2)]]
                         } else {
                             set w2 [format "%.1f" $d2]
                       } else {
                           set w2 [format "%.2f" $d2]
                     } else {
                         set w2 [format "%.3f" $d2]
                   } else {
                       set w2 [format "%.4f" $d2]
                 } else {
                     set w2 [format "%.5f" $d2]
               if {$d2 > 0.0} {
                 set s2 [format "+%s*#102" $w2]
               } elseif {$d2 < 0.0} {
                   set s2 [format "%s*#102" $w2]
                 } else {
                     set s2 "NONE"
        set w4 [format "%.4f" $vx]
                set w4 [format "%d." [expr round($vx)]]
              } else {
                  set w4 [format "%.1f" $vx]
            } else {
                set w4 [format "%.2f" $vx]
          } else {
              set w4 [format "%.3f" $vx]
        if {$vx > 0.0} {
        } elseif {$vx < 0.0} {
          } else {
              set s4 "NONE"
未完待续。。。。
作者 南京六合标子
发表于 2026-1-2 15:59:35 | 显示全部楼层
谢谢大佬分享
35
发表于 2026-3-30 13:27:04 来自手机 | 显示全部楼层
感谢大佬分享!大佬牛掰!👍👍👍
发表于 2026-4-18 10:40:52 | 显示全部楼层
发表于 2026-4-19 20:14:08 | 显示全部楼层
感谢楼主无私分享,支持一下,非常实用的好资源!
发表于 2026-7-28 21:19:56 | 显示全部楼层
GMT+8, 2026-11-18 20:01
