查看: 851|回复: 7
[分享] 手把手教你制作UG四五轴宏联动后处理(八)
发表于 2025-12-29 05:43:34 | 显示全部楼层 |阅读模式
#******************计算Zrtcp**********************************
        set e1 [expr sin($rad_a)*sin($rad_c)]
        set e2 [expr -1.0*sin($rad_a)*cos($rad_c)]
        set e3 [expr cos($rad_a)-1.0]
        set d1 [expr round($e1*1000000.0)/1000000.0]
        set d2 [expr round($e2*1000000.0)/1000000.0]
        set d3 [expr round($e3*1000000.0)/1000000.0]
        set vz [expr round($mom_pos(2)*10000.0)/10000.0]
        set w1 [format "%.6f" $d1]
        if {![string compare "-1.000000" $w1]} {
          set s1 "-#101"
        } elseif {![string compare "1.000000" $w1]} {
            set s1 "#101"
          } else {
              if {[string index $w1 end-0] == "0"} {
                if {[string index $w1 end-1] == "0"} {
                  if {[string index $w1 end-2] == "0"} {
                    if {[string index $w1 end-3] == "0"} {
                      if {[string index $w1 end-4] == "0"} {
                        if {[string index $w1 end-5] == "0"} {
                          set w1 [format "%d." [expr round($d1)]]
                        } else {
                            set w1 [format "%.1f" $d1]
                      } else {
                          set w1 [format "%.2f" $d1]
                    } else {
                        set w1 [format "%.3f" $d1]
                  } else {
                      set w1 [format "%.4f" $d1]
                } else {
                    set w1 [format "%.5f" $d1]
              if {$d1 != 0.0} {
                set s1 [format "%s*#101" $w1]
              } else {
                  set s1 "NONE"
        set w2 [format "%.6f" $d2]
        if {![string compare "-1.000000" $w2]} {
          set s2 "-#102"
        } elseif {![string compare "1.000000" $w2]} {
            set s2 "+#102"
          } else {
              if {[string index $w2 end-0] == "0"} {
                if {[string index $w2 end-1] == "0"} {
                  if {[string index $w2 end-2] == "0"} {
                    if {[string index $w2 end-3] == "0"} {
                      if {[string index $w2 end-4] == "0"} {
                        if {[string index $w2 end-5] == "0"} {
                          set w2 [format "%d." [expr round($d2)]]
                        } else {
                            set w2 [format "%.1f" $d2]
                      } else {
                          set w2 [format "%.2f" $d2]
                    } else {
                        set w2 [format "%.3f" $d2]
                  } else {
                      set w2 [format "%.4f" $d2]
                } else {
                    set w2 [format "%.5f" $d2]
              if {$d2 > 0.0} {
                set s2 [format "+%s*#102" $w2]
              } elseif {$d2 < 0.0} {
                  set s2 [format "%s*#102" $w2]
                } else {
                    set s2 "NONE"
         set w3 [format "%.6f" $d3]
         if {![string compare "-1.000000" $w3]} {
           set s3 "-#103"
         } elseif {![string compare "1.000000" $w3]} {
             set s3 "+#103"
           } else {
               if {[string index $w3 end-0] == "0"} {
                 if {[string index $w3 end-1] == "0"} {
                   if {[string index $w3 end-2] == "0"} {
                     if {[string index $w3 end-3] == "0"} {
                       if {[string index $w3 end-4] == "0"} {
                         if {[string index $w3 end-5] == "0"} {
                           set w3 [format "%d." [expr round($d3)]]
                         } else {
                             set w3 [format "%.1f" $d3]
                       } else {
                           set w3 [format "%.2f" $d3]
                     } else {
                         set w3 [format "%.3f" $d3]
                   } else {
                       set w3 [format "%.4f" $d3]
                 } else {
                     set w3 [format "%.5f" $d3]
               if {$d3 > 0.0} {
                 set s3 [format "+%s*#103" $w3]
               } elseif {$d3 < 0.0} {
                   set s3 [format "%s*#103" $w3]
                 } else {
                     set s3 "NONE"
        set w4 [format "%.4f" $vz]
        if {[string index $w4 end-0] == "0"} {
          if {[string index $w4 end-1] == "0"} {
            if {[string index $w4 end-2] == "0"} {
              if {[string index $w4 end-3] == "0"} {
                set w4 [format "%d." [expr round($vz)]]
              } else {
                  set w4 [format "%.1f" $vz]
            } else {
                set w4 [format "%.2f" $vz]
          } else {
              set w4 [format "%.3f" $vz]
        if {$vz > 0.0} {
          set s4 [format "+%s" $w4]
        } elseif {$vz < 0.0} {
            set s4 [format "%s" $w4]
          } else {
              set s4 "NONE"
        if {[string compare "NONE" $s1] && [string compare "NONE" $s2] && [string compare "NONE" $s3]} {
          set s [format "%s%s%s" $s1 $s2 $s3]
        } elseif {[string compare "NONE" $s1] && ![string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
            set s $s1
          } elseif {![string compare "NONE" $s1] && [string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
              set s $s2
            } elseif {![string compare "NONE" $s1] && ![string compare "NONE" $s2] && [string compare "NONE" $s3]} {
                set s $s3
              } elseif {[string compare "NONE" $s1] && [string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
                  set s [format "%s%s" $s1 $s2]
                } elseif {[string compare "NONE" $s1] && ![string compare "NONE" $s2] && [string compare "NONE" $s3]} {
                    set s [format "%s%s" $s1 $s3]
                  } elseif {![string compare "NONE" $s1] && [string compare "NONE" $s2] && [string compare "NONE" $s3]} {
                      set s [format "%s%s" $s2 $s3]
                    } else {
                        set s "NONE"
        if {[string compare "NONE" $s] && [string compare "NONE" $s4]} {
          set sz [format "\[%s%s\]" $s $s4]
        } elseif {![string compare "NONE" $s] && [string compare "NONE" $s4]} {
            set sz $s4
          } elseif {[string compare "NONE" $s] && ![string compare "NONE" $s4]} {
              set sz [format "\[%s\]" $s]
            } else {
                set sz "0."
        return 1
      return 0
      点击确定。
  (4).为"快速移动"事件下的G0 G90 rap1 rap2 A C行添加输出条件
      PB__CMD_check_block_rapid_traverse,编辑TCL代码如下:
      global dpp_path_type
      if {![string compare "3X" $dpp_path_type]} {
        return 1
      return 0
      点击确定。
  (5).为"快速移动"事件下的G43 G0 G90 rap3 A C H1 M8行添加输出条件
      PB__CMD_check_block_rapid_traverse_1,编辑TCL代码如下:
        return 1
      return 0
      点击确定。
未完待续。。。。。
作者  南京六合标子
发表于 2025-12-29 09:22:12 | 显示全部楼层
虽说看不懂,但我觉得你很牛逼
25
发表于 2025-12-29 12:16:26 | 显示全部楼层
应该写本书啊。
发表于 2025-12-29 12:43:08 来自手机 | 显示全部楼层
感谢巨佬提供技术支持
发表于 2026-1-2 16:02:02 | 显示全部楼层
发表于 2026-3-30 13:25:35 来自手机 | 显示全部楼层
感谢大佬分享!大佬牛掰!👍👍👍
发表于 2026-4-18 10:41:27 | 显示全部楼层
发表于 2026-4-19 19:59:08 | 显示全部楼层
感谢楼主无私分享,支持一下,非常实用的好资源!
发表于 2026-7-28 21:15:09 | 显示全部楼层
GMT+8, 2026-11-18 20:01
