查看: 822|回复: 6
[分享] 手把手教你制作UG四五轴宏联动后处理(九)
发表于 2025-12-30 15:37:42 | 显示全部楼层 |阅读模式
(6).在"快速移动"事件下的G43 G0 G90 rap3 A C H1 M8行下面添加一个新行
      G0 G90 文本元素 A C,将文本元素内容改成X$sx Y$sy Z$sz,添加输出
      条件PB__CMD_check_block_rapid_move2,编辑TCL代码如下:
      global dpp_path_type
      global e1 e2 e3 d1 d2 d3 vx vy vz rad_a rad_c
      global w1 w2 w3 s s1 s2 s3 s4 sx sy sz
      global mom_pos mom_out_angle_pos
      if {![string compare "5X" $dpp_path_type]} {
        set rad_a [expr $mom_out_angle_pos(0)*0.01745329252]
        set rad_c [expr $mom_out_angle_pos(1)*0.01745329252]
        #******************计算Xrtcp**********************
        set e1 [expr cos($rad_c)-1.0]
        set e2 [expr sin($rad_c)]
        set d1 [expr round($e1*1000000.0)/1000000.0]
        set d2 [expr round($e2*1000000.0)/1000000.0]
        set vx [expr round($mom_pos(0)*10000.0)/10000.0]
        set w1 [format "%.6f" $d1]
        if {![string compare "-1.000000" $w1]} {
          set s1 "-#101"
        } elseif {![string compare "1.000000" $w1]} {
            set s1 "#101"
          } else {
              if {[string index $w1 end-0] == "0"} {
                if {[string index $w1 end-1] == "0"} {
                  if {[string index $w1 end-2] == "0"} {
                    if {[string index $w1 end-3] == "0"} {
                      if {[string index $w1 end-4] == "0"} {
                        if {[string index $w1 end-5] == "0"} {
                          set w1 [format "%d." [expr round($d1)]]
                        } else {
                            set w1 [format "%.1f" $d1]
                      } else {
                          set w1 [format "%.2f" $d1]
                    } else {
                        set w1 [format "%.3f" $d1]
                  } else {
                      set w1 [format "%.4f" $d1]
                } else {
                    set w1 [format "%.5f" $d1]
              if {$d1 != 0.0} {
                set s1 [format "%s*#101" $w1]
              } else {
                  set s1 "NONE"
         set w2 [format "%.6f" $d2]
         if {![string compare "-1.000000" $w2]} {
           set s2 "-#102"
         } elseif {![string compare "1.000000" $w2]} {
             set s2 "+#102"
           } else {
               if {[string index $w2 end-0] == "0"} {
                 if {[string index $w2 end-1] == "0"} {
                   if {[string index $w2 end-2] == "0"} {
                     if {[string index $w2 end-3] == "0"} {
                       if {[string index $w2 end-4] == "0"} {
                         if {[string index $w2 end-5] == "0"} {
                           set w2 [format "%d." [expr round($d2)]]
                         } else {
                             set w2 [format "%.1f" $d2]
                       } else {
                           set w2 [format "%.2f" $d2]
                     } else {
                         set w2 [format "%.3f" $d2]
                   } else {
                       set w2 [format "%.4f" $d2]
                 } else {
                     set w2 [format "%.5f" $d2]
               if {$d2 > 0.0} {
                 set s2 [format "+%s*#102" $w2]
               } elseif {$d2 < 0.0} {
                   set s2 [format "%s*#102" $w2]
                 } else {
                     set s2 "NONE"
        set w4 [format "%.4f" $vx]
        if {[string index $w4 end-0] == "0"} {
          if {[string index $w4 end-1] == "0"} {
            if {[string index $w4 end-2] == "0"} {
              if {[string index $w4 end-3] == "0"} {
                set w4 [format "%d." [expr round($vx)]]
              } else {
                  set w4 [format "%.1f" $vx]
            } else {
                set w4 [format "%.2f" $vx]
          } else {
              set w4 [format "%.3f" $vx]
        if {$vx > 0.0} {
          set s4 [format "+%s" $w4]
        } elseif {$vx < 0.0} {
            set s4 [format "%s" $w4]
          } else {
              set s4 "NONE"
       if {[string compare "NONE" $s1] && ![string compare "NONE" $s2]} {
         set s $s1
       } elseif {![string compare "NONE" $s1] && [string compare "NONE" $s2]} {
           set s $s2
         } elseif {[string compare "NONE" $s1] && [string compare "NONE" $s2]} {
             set s [format "%s%s" $s1 $s2]
           } else {
               set s "NONE"
        if {[string compare "NONE" $s] && [string compare "NONE" $s4]} {
          set sx [format "\[%s%s\]" $s $s4]
        } elseif {![string compare "NONE" $s] && [string compare "NONE" $s4]} {
            set sx $s4
          } elseif {[string compare "NONE" $s] && ![string compare "NONE" $s4]} {
              set sx [format "\[%s\]" $s]
            } else {
                set sx "0."
        #*********************计算Yrtcp**********************************
        set e1 [expr cos($rad_a)*cos($rad_c)-1.0]
        set e2 [expr -1.0*cos($rad_a)*sin($rad_c)]
        set e3 [expr sin($rad_a)]
        set d3 [expr round($e3*1000000.0)/1000000.0]
        set vy [expr round($mom_pos(1)*10000.0)/10000.0]
          set s1 "-#102"
            set s1 "#102"
          } else {
                        } else {
                      } else {
                    } else {
                  } else {
                } else {
              if {$d1 != 0.0} {
                set s1 [format "%s*#102" $w1]
              } else {
                  set s1 "NONE"
          set s2 "-#101"
            set s2 "+#101"
          } else {
                        } else {
                      } else {
                    } else {
                  } else {
                } else {
              if {$d2 > 0.0} {
                set s2 [format "+%s*#101" $w2]
                  set s2 [format "%s*#101" $w2]
                } else {
                    set s2 "NONE"
未完待续。。。。。
作者 南京六合标子
发表于 2026-1-2 16:02:59 | 显示全部楼层
发表于 2026-3-30 13:25:12 来自手机 | 显示全部楼层
感谢大佬分享!大佬牛掰!👍👍👍
发表于 2026-4-18 10:41:47 | 显示全部楼层
发表于 2026-4-18 12:57:57 | 显示全部楼层
发表于 2026-7-28 21:14:53 | 显示全部楼层
发表于 2026-7-29 10:01:13 | 显示全部楼层
谢谢楼主分享啊!
发表于 2026-7-29 13:22:30 | 显示全部楼层
学习学习
GMT+8, 2026-11-18 20:01
