查看: 1033|回复: 11
[分享] 手把手教你制作UG四五轴宏联动后处理(十)
发表于 2025-12-30 15:40:18 | 显示全部楼层 |阅读模式
  set w3 [format "%.6f" $d3]
        if {![string compare "-1.000000" $w3]} {
          set s3 "-#103"
        } elseif {![string compare "1.000000" $w3]} {
            set s3 "+#103"
          } else {
              if {[string index $w3 end-0] == "0"} {
                if {[string index $w3 end-1] == "0"} {
                  if {[string index $w3 end-2] == "0"} {
                    if {[string index $w3 end-3] == "0"} {
                      if {[string index $w3 end-4] == "0"} {
                        if {[string index $w3 end-5] == "0"} {
                          set w3 [format "%d." [expr round($d3)]]
                        } else {
                            set w3 [format "%.1f" $d3]
                      } else {
                          set w3 [format "%.2f" $d3]
                    } else {
                        set w3 [format "%.3f" $d3]
                  } else {
                      set w3 [format "%.4f" $d3]
                } else {
                    set w3 [format "%.5f" $d3]
              if {$d3 > 0.0} {
                set s3 [format "+%s*#103" $w3]
              } elseif {$d3 < 0.0} {
                  set s3 [format "%s*#103" $w3]
                } else {
                    set s3 "NONE"
        set w4 [format "%.4f" $vy]
        if {[string index $w4 end-0] == "0"} {
          if {[string index $w4 end-1] == "0"} {
            if {[string index $w4 end-2] == "0"} {
              if {[string index $w4 end-3] == "0"} {
                set w4 [format "%d." [expr round($vy)]]
              } else {
                  set w4 [format "%.1f" $vy]
            } else {
                set w4 [format "%.2f" $vy]
          } else {
              set w4 [format "%.3f" $vy]
        if {$vy > 0.0} {
          set s4 [format "+%s" $w4]
        } elseif {$vy < 0.0} {
            set s4 [format "%s" $w4]
          } else {
              set s4 "NONE"
       if {[string compare "NONE" $s1] && [string compare "NONE" $s2] && [string compare "NONE" $s3]} {
          set s [format "%s%s%s" $s1 $s2 $s3]
       } elseif {[string compare "NONE" $s1] && ![string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
           set s $s1
         } elseif {![string compare "NONE" $s1] && [string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
             set s $s2
           } elseif {![string compare "NONE" $s1] && ![string compare "NONE" $s2] && [string compare "NONE" $s3]} {
               set s $s3
             } elseif {[string compare "NONE" $s1] && [string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
                 set s [format "%s%s" $s1 $s2]
               } elseif {[string compare "NONE" $s1] && ![string compare "NONE" $s2] && [string compare "NONE" $s3]} {
                   set s [format "%s%s" $s1 $s3]
                 } elseif {![string compare "NONE" $s1] && [string compare "NONE" $s2] && [string compare "NONE" $s3]} {
                     set s [format "%s%s" $s2 $s3]
                   } else {
                       set s "NONE"
        if {[string compare "NONE" $s] && [string compare "NONE" $s4]} {
          set sy [format "\[%s%s\]" $s $s4]
        } elseif {![string compare "NONE" $s] && [string compare "NONE" $s4]} {
            set sy $s4
          } elseif {[string compare "NONE" $s] && ![string compare "NONE" $s4]} {
              set sy [format "\[%s\]" $s]
           } else {
               set sy "0."
        #******************计算Zrtcp**********************************
        set e1 [expr sin($rad_a)*sin($rad_c)]
        set e2 [expr -1.0*sin($rad_a)*cos($rad_c)]
        set e3 [expr cos($rad_a)-1.0]
        set d1 [expr round($e1*1000000.0)/1000000.0]
        set d2 [expr round($e2*1000000.0)/1000000.0]
        set d3 [expr round($e3*1000000.0)/1000000.0]
        set vz [expr round($mom_pos(2)*10000.0)/10000.0]
        set w1 [format "%.6f" $d1]
        if {![string compare "-1.000000" $w1]} {
          set s1 "-#101"
        } elseif {![string compare "1.000000" $w1]} {
            set s1 "#101"
          } else {
              if {[string index $w1 end-0] == "0"} {
                if {[string index $w1 end-1] == "0"} {
                  if {[string index $w1 end-2] == "0"} {
                    if {[string index $w1 end-3] == "0"} {
                      if {[string index $w1 end-4] == "0"} {
                        if {[string index $w1 end-5] == "0"} {
                          set w1 [format "%d." [expr round($d1)]]
                        } else {
                            set w1 [format "%.1f" $d1]
                      } else {
                          set w1 [format "%.2f" $d1]
                    } else {
                        set w1 [format "%.3f" $d1]
                  } else {
                      set w1 [format "%.4f" $d1]
                } else {
                    set w1 [format "%.5f" $d1]
              if {$d1 != 0.0} {
                set s1 [format "%s*#101" $w1]
              } else {
                  set s1 "NONE"
        set w2 [format "%.6f" $d2]
        if {![string compare "-1.000000" $w2]} {
          set s2 "-#102"
        } elseif {![string compare "1.000000" $w2]} {
            set s2 "+#102"
          } else {
              if {[string index $w2 end-0] == "0"} {
                if {[string index $w2 end-1] == "0"} {
                  if {[string index $w2 end-2] == "0"} {
                    if {[string index $w2 end-3] == "0"} {
                      if {[string index $w2 end-4] == "0"} {
                        if {[string index $w2 end-5] == "0"} {
                          set w2 [format "%d." [expr round($d2)]]
                        } else {
                            set w2 [format "%.1f" $d2]
                      } else {
                          set w2 [format "%.2f" $d2]
                    } else {
                        set w2 [format "%.3f" $d2]
                  } else {
                      set w2 [format "%.4f" $d2]
                } else {
                    set w2 [format "%.5f" $d2]
              if {$d2 > 0.0} {
                set s2 [format "+%s*#102" $w2]
              } elseif {$d2 < 0.0} {
                  set s2 [format "%s*#102" $w2]
                } else {
                    set s2 "NONE"
           set s3 "-#103"
             set s3 "+#103"
           } else {
                         } else {
                       } else {
                     } else {
                   } else {
                 } else {
               if {$d3 > 0.0} {
                 } else {
                     set s3 "NONE"
未完待续。。。。
作者 南京六合标子 ,一个二十年的五轴师傅
34
发表于 2025-12-30 18:53:21 | 显示全部楼层
谢谢分享,期待继续!!!
发表于 2025-12-31 08:31:01 来自手机 | 显示全部楼层
看不懂。有注释?
发表于 2025-12-31 08:45:25 | 显示全部楼层
虽然我看不懂,但我觉得你很牛,先赞一个!
发表于 2026-1-2 16:04:46 | 显示全部楼层
发表于 2026-3-30 13:24:51 来自手机 | 显示全部楼层
感谢大佬分享!大佬牛掰!👍👍👍
发表于 2026-4-18 10:42:06 | 显示全部楼层
发表于 2026-4-18 12:58:14 | 显示全部楼层
发表于 2026-4-19 19:42:44 | 显示全部楼层
感谢楼主无私分享,支持一下,非常实用的好资源!
发表于 2026-5-26 20:04:18 | 显示全部楼层
谢谢分享!
GMT+8, 2026-11-18 20:11
