查看: 693|回复: 6
[分享] 手把手教你制作UG四五轴宏联动后处理(十四)
发表于 2026-1-1 05:22:49 | 显示全部楼层 |阅读模式
set w3 [format "%.6f" $d3]
  if {![string compare "-1.000000" $w3]} {
    set s3 "-#102"
  } elseif {![string compare "1.000000" $w3]} {
      set s3 "+#102"
    } else {
        if {[string index $w3 end-0] == "0"} {
          if {[string index $w3 end-1] == "0"} {
            if {[string index $w3 end-2] == "0"} {
               if {[string index $w3 end-3] == "0"} {
                 if {[string index $w3 end-4] == "0"} {
                   if {[string index $w3 end-5] == "0"} {
                     set w3 [format "%d." [expr round($d3)]]
                   } else {
                       set w3 [format "%.1f" $d3]
                 } else {
                     set w3 [format "%.2f" $d3]
               } else {
                   set w3 [format "%.3f" $d3]
             } else {
                 set w3 [format "%.4f" $d3]
           } else {
               set w3 [format "%.5f" $d3]
        if {$d3 > 0.0} {
          set s3 [format "+%s*#102" $w3]
        } elseif {$d3 < 0.0} {
            set s3 [format "%s*#102" $w3]
          } else {
              set s3 "NONE"
  set w4 [format "%.4f" $vz]
  if {[string index $w4 end-0] == "0"} {
    if {[string index $w4 end-1] == "0"} {
      if {[string index $w4 end-2] == "0"} {
        if {[string index $w4 end-3] == "0"} {
          set w4 [format "%d." [expr round($vz)]]
        } else {
            set w4 [format "%.1f" $vz]
      } else {
          set w4 [format "%.2f" $vz]
    } else {
        set w4 [format "%.3f" $vz]
  if {$vz > 0.0} {
    set s4 [format "+%s" $w4]
  } elseif {$vz < 0.0} {
      set s4 [format "%s" $w4]
    } else {
        set s4 "NONE"
  if {[string compare "NONE" $s1] && [string compare "NONE" $s2] && [string compare "NONE" $s3]} {
    set s [format "%s%s%s" $s1 $s2 $s3]
  } elseif {[string compare "NONE" $s1] && ![string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
      set s $s1
    } elseif {![string compare "NONE" $s1] && [string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
        set s $s2
      } elseif {![string compare "NONE" $s1] && ![string compare "NONE" $s2] && [string compare "NONE" $s3]} {
          set s $s3
        } elseif {[string compare "NONE" $s1] && [string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
            set s [format "%s%s" $s1 $s2]
          } elseif {[string compare "NONE" $s1] && ![string compare "NONE" $s2] && [string compare "NONE" $s3]} {
              set s [format "%s%s" $s1 $s3]
            } elseif {![string compare "NONE" $s1] && [string compare "NONE" $s2] && [string compare "NONE" $s3]} {
                set s [format "%s%s" $s2 $s3]
              } else {
                  set s "NONE"
  if {[string compare "NONE" $s] && [string compare "NONE" $s4]} {
    set sz [format "\[%s%s\]" $s $s4]
  } elseif {![string compare "NONE" $s] && [string compare "NONE" $s4]} {
      set sz $s4
    } elseif {[string compare "NONE" $s] && ![string compare "NONE" $s4]} {
        set sz [format "\[%s\]" $s]
      } else {
          set sz "0."
  return 1
return 0
       点击确定。
  (22).将"初始移动"事件下的G0 G90 G(54~59) 文本元素1 文本元素2 B C S M3行复制到"第一次移动"事件下的G0 G90 (54~59) X Y B C S M3行下面。
  (23).在"初始移动"事件下的G0 G90 G(54~59) 文本元素1 文本元素2 B C S M3行下面添加G43 Z H1 M8行,
       添加输出条件PB__CMD_check_block_initial_move2,编辑TCL代码如下:
       global dpp_path_type
       if {![string compare "3X" $dpp_path_type]} {
          return 1
       return 0
       点击确定。
  (24).将"初始移动"事件下的G43 Z H1 M8行复制到"第一次移动"事件下的G0 G90 (54~59) 文本元素1 文本元素2 X Y B C S M3行下面。
  (25).在"初始移动"事件下的G43 Z H1 M8行下面添加G43 文本元素 H1 M8行,将文本元素内容改为Z$sz,
       添加输出条件PB__CMD_check_block_initial_move3,编辑TCL代码如下:
       if {![string compare "5X" $dpp_path_type]} {
         return 1
       return 0
       点击确定。
  (26).将"初始移动"事件下的G43 文本元素 H1 M8行复制到"第一次移动"事件下的G43 Z H1 M8行下面。
7.在"程序和刀轨"选项卡中,选择左侧"运动"选项:
  (1).将"圆周移动"事件下的G17 G2 G90 X Y Z I J K F S行中的G17和S元素删除,将G2元素设置为强制输出,
      添加输出条件PB__CMD_check_block_circular_move,编辑TCL代码如下:
        return 1
      return 0
      点击确定。
  (2).将"线性移动"事件下的G41 G17 G1 G90 X Y Z B C F S D1 M3 M8行中的G17,S,M3,M8元素删除,
      添加输出条件PB__CMD_check_block_linear_move,编辑TCL代码如下:
        return 1
      return 0
      点击确定。
  (3).在"线性移动"事件下的G41 G1 G90 X Y Z B C F D1行下面添加G41 G1 G90 文本元素 B C F D1行,
       将文本元素内容改为X$sx Y$sy Z$sz,添加输出条件PB_CMD__check_block_linear_move_1,
       编辑TCL代码如下:
global e1 e2 e3 d1 d2 d3 vx vy vz rad_b rad_c
global w1 w2 w3 s s1 s2 s3 s4 sx sy sz
global mom_out_angle_pos mom_pos
  set rad_b [expr $mom_out_angle_pos(0)*0.01745329252]
  set rad_c [expr $mom_out_angle_pos(1)*0.01745329252]
  #**********************计算Xrtcp*********************
  set e1 [expr cos($rad_b)*cos($rad_c)-1.0]
  set e2 [expr cos($rad_b)*sin($rad_c)]
  set e3 [expr -1.0*sin($rad_b)]
  set d1 [expr round($e1*1000000.0)/1000000.0]
  set d2 [expr round($e2*1000000.0)/1000000.0]
  set d3 [expr round($e3*1000000.0)/1000000.0]
  set vx [expr round($mom_pos(0)*10000.0)/10000.0]
  set w1 [format "%.6f" $d1]
  if {![string compare "-1.000000" $w1]} {
    set s1 "-#101"
  } elseif {![string compare "1.000000" $w1]} {
      set s1 "#101"
    } else {
        if {[string index $w1 end-0] == "0"} {
          if {[string index $w1 end-1] == "0"} {
            if {[string index $w1 end-2] == "0"} {
              if {[string index $w1 end-3] == "0"} {
                if {[string index $w1 end-4] == "0"} {
                  if {[string index $w1 end-5] == "0"} {
                     set w1 [format "%d." [expr round($d1)]]
                   } else {
                       set w1 [format "%.1f" $d1]
                 } else {
                     set w1 [format "%.2f" $d1]
               } else {
                   set w1 [format "%.3f" $d1]
             } else {
                 set w1 [format "%.4f" $d1]
           } else {
               set w1 [format "%.5f" $d1]
        if {$d1 != 0.0} {
          set s1 [format "%s*#101" $w1]
        } else {
            set s1 "NONE"
  set w2 [format "%.6f" $d2]
  if {![string compare "-1.000000" $w2]} {
    set s2 "-#102"
  } elseif {![string compare "1.000000" $w2]} {
      set s2 "+#102"
    } else {
        if {[string index $w2 end-0] == "0"} {
          if {[string index $w2 end-1] == "0"} {
            if {[string index $w2 end-2] == "0"} {
               if {[string index $w2 end-3] == "0"} {
                 if {[string index $w2 end-4] == "0"} {
                   if {[string index $w2 end-5] == "0"} {
                     set w2 [format "%d." [expr round($d2)]]
                   } else {
                       set w2 [format "%.1f" $d2]
                 } else {
                     set w2 [format "%.2f" $d2]
               } else {
                   set w2 [format "%.3f" $d2]
             } else {
                 set w2 [format "%.4f" $d2]
           } else {
               set w2 [format "%.5f" $d2]
        if {$d2 > 0.0} {
          set s2 [format "+%s*#102" $w2]
        } elseif {$d2 < 0.0} {
            set s2 [format "%s*#102" $w2]
          } else {
              set s2 "NONE"
未完待续。。。。
发表于 2026-1-1 13:52:29 | 显示全部楼层
谢谢大师的无私分享
发表于 2026-1-2 07:38:49 | 显示全部楼层
谢谢分享,,
发表于 2026-1-2 16:15:56 | 显示全部楼层
谢谢大师的无私分享
发表于 2026-1-10 23:02:25 | 显示全部楼层
我很好奇你是专业搞开发的吗?缩进做的很好,一般人写TCL语言不太注重缩进这些,只要能跑通就行,不管可读性
65
 楼主| 发表于 2026-1-11 00:28:23 | 显示全部楼层
fbph2003 发表于 2026-1-10 23:02
我很好奇你是专业搞开发的吗?缩进做的很好,一般人写TCL语言不太注重缩进这些,只要能跑通就行,不管可读 ...
是的,做过C/C++
35
发表于 2026-3-27 13:49:15 来自手机 | 显示全部楼层
发表于 2026-4-19 09:18:02 | 显示全部楼层
感谢楼主无私分享,支持一下,非常实用的好资源!
GMT+8, 2026-11-18 20:31
