查看: 705|回复: 7
[分享] 手把手教你制作UG四五轴宏联动后处理(十六)
发表于 2026-1-2 03:22:45 | 显示全部楼层 |阅读模式
  #**********************计算Zrtcp*********************
  set e1 [expr cos($rad_b)-1.0]
  set e2 [expr sin($rad_b)*cos($rad_c)]
  set e3 [expr sin($rad_b)*sin($rad_c)]
  set d1 [expr round($e1*1000000.0)/1000000.0]
  set d2 [expr round($e2*1000000.0)/1000000.0]
  set d3 [expr round($e3*1000000.0)/1000000.0]
  set vz [expr round($mom_pos(2)*10000.0)/10000.0]
  set w1 [format "%.6f" $d1]
  if {![string compare "-1.000000" $w1]} {
    set s1 "-#103"
  } elseif {![string compare "1.000000" $w1]} {
      set s1 "#103"
    } else {
        if {[string index $w1 end-0] == "0"} {
          if {[string index $w1 end-1] == "0"} {
            if {[string index $w1 end-2] == "0"} {
              if {[string index $w1 end-3] == "0"} {
                if {[string index $w1 end-4] == "0"} {
                  if {[string index $w1 end-5] == "0"} {
                     set w1 [format "%d." [expr round($d1)]]
                   } else {
                       set w1 [format "%.1f" $d1]
                 } else {
                     set w1 [format "%.2f" $d1]
               } else {
                   set w1 [format "%.3f" $d1]
             } else {
                 set w1 [format "%.4f" $d1]
           } else {
               set w1 [format "%.5f" $d1]
        if {$d1 != 0.0} {
          set s1 [format "%s*#103" $w1]
        } else {
            set s1 "NONE"
  set w2 [format "%.6f" $d2]
  if {![string compare "-1.000000" $w2]} {
    set s2 "-#101"
  } elseif {![string compare "1.000000" $w2]} {
      set s2 "+#101"
    } else {
        if {[string index $w2 end-0] == "0"} {
          if {[string index $w2 end-1] == "0"} {
            if {[string index $w2 end-2] == "0"} {
               if {[string index $w2 end-3] == "0"} {
                 if {[string index $w2 end-4] == "0"} {
                   if {[string index $w2 end-5] == "0"} {
                     set w2 [format "%d." [expr round($d2)]]
                   } else {
                       set w2 [format "%.1f" $d2]
                 } else {
                     set w2 [format "%.2f" $d2]
               } else {
                   set w2 [format "%.3f" $d2]
             } else {
                 set w2 [format "%.4f" $d2]
           } else {
               set w2 [format "%.5f" $d2]
        if {$d2 > 0.0} {
          set s2 [format "+%s*#101" $w2]
        } elseif {$d2 < 0.0} {
            set s2 [format "%s*#101" $w2]
          } else {
              set s2 "NONE"
  set w3 [format "%.6f" $d3]
  if {![string compare "-1.000000" $w3]} {
    set s3 "-#102"
  } elseif {![string compare "1.000000" $w3]} {
      set s3 "+#102"
    } else {
        if {[string index $w3 end-0] == "0"} {
          if {[string index $w3 end-1] == "0"} {
            if {[string index $w3 end-2] == "0"} {
               if {[string index $w3 end-3] == "0"} {
                 if {[string index $w3 end-4] == "0"} {
                   if {[string index $w3 end-5] == "0"} {
                     set w3 [format "%d." [expr round($d3)]]
                   } else {
                       set w3 [format "%.1f" $d3]
                 } else {
                     set w3 [format "%.2f" $d3]
               } else {
                   set w3 [format "%.3f" $d3]
             } else {
                 set w3 [format "%.4f" $d3]
           } else {
               set w3 [format "%.5f" $d3]
        if {$d3 > 0.0} {
          set s3 [format "+%s*#102" $w3]
        } elseif {$d3 < 0.0} {
            set s3 [format "%s*#102" $w3]
          } else {
              set s3 "NONE"
  set w4 [format "%.4f" $vz]
  if {[string index $w4 end-0] == "0"} {
    if {[string index $w4 end-1] == "0"} {
      if {[string index $w4 end-2] == "0"} {
        if {[string index $w4 end-3] == "0"} {
          set w4 [format "%d." [expr round($vz)]]
        } else {
            set w4 [format "%.1f" $vz]
      } else {
          set w4 [format "%.2f" $vz]
    } else {
        set w4 [format "%.3f" $vz]
  if {$vz > 0.0} {
    set s4 [format "+%s" $w4]
  } elseif {$vz < 0.0} {
      set s4 [format "%s" $w4]
    } else {
        set s4 "NONE"
  if {[string compare "NONE" $s1] && [string compare "NONE" $s2] && [string compare "NONE" $s3]} {
    set s [format "%s%s%s" $s1 $s2 $s3]
  } elseif {[string compare "NONE" $s1] && ![string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
      set s $s1
    } elseif {![string compare "NONE" $s1] && [string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
        set s $s2
      } elseif {![string compare "NONE" $s1] && ![string compare "NONE" $s2] && [string compare "NONE" $s3]} {
          set s $s3
        } elseif {[string compare "NONE" $s1] && [string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
            set s [format "%s%s" $s1 $s2]
          } elseif {[string compare "NONE" $s1] && ![string compare "NONE" $s2] && [string compare "NONE" $s3]} {
              set s [format "%s%s" $s1 $s3]
            } elseif {![string compare "NONE" $s1] && [string compare "NONE" $s2] && [string compare "NONE" $s3]} {
                set s [format "%s%s" $s2 $s3]
              } else {
                  set s "NONE"
  if {[string compare "NONE" $s] && [string compare "NONE" $s4]} {
    set sz [format "\[%s%s\]" $s $s4]
  } elseif {![string compare "NONE" $s] && [string compare "NONE" $s4]} {
      set sz $s4
    } elseif {[string compare "NONE" $s] && ![string compare "NONE" $s4]} {
        set sz [format "\[%s\]" $s]
      } else {
          set sz "0."
  return 1
return 0
      点击确定。
  (4).为"快速移动"事件下的G0 G90 rap1 rap2 B C行添加输出条件
      PB__CMD_check_block_rapid_traverse,编辑TCL代码如下:
      global dpp_path_type
      if {![string compare "3X" $dpp_path_type]} {
        return 1
      return 0
      点击确定。
  (5).为"快速移动"事件下的G43 G0 G90 rap3 B C H1 M8行添加输出条件
      PB__CMD_check_block_rapid_traverse_1,编辑TCL代码如下:
        return 1
      return 0
      点击确定。
未完待续。。。。。
点评
牛而逼之  发表于 2026-1-2 16:50
发表于 2026-1-2 15:50:11 | 显示全部楼层
谢谢大佬的教学
发表于 2026-1-2 20:04:32 | 显示全部楼层
发表于 2026-1-3 16:02:33 | 显示全部楼层
很难啊,少一个符号或是字母都不行,没有扎实的基础是不行的。有没有好的软件或是什么方法检查出错的地方
35
发表于 2026-3-30 13:21:44 来自手机 | 显示全部楼层
感谢大佬分享!大佬牛掰!👍👍👍
发表于 2026-4-18 12:55:59 | 显示全部楼层
发表于 2026-4-18 14:47:35 | 显示全部楼层
GMT+8, 2026-11-18 20:31
