查看: 679|回复: 6
[分享] 手把手教你制作UG四五轴宏联动后处理(十七)
发表于 2026-1-4 13:38:51 | 显示全部楼层 |阅读模式
  (6).在"快速移动"事件下的G43 G0 G90 rap3 B C H1 M8行下面添加一个新行
      G0 G90 文本元素 B C,将文本元素内容改成X$sx Y$sy Z$sz,添加输出
      条件PB__CMD_check_block_rapid_move2,编辑TCL代码如下:
global dpp_path_type
global e1 e2 e3
global d1 d2 d3
global vx vy vz
global w1 w2 w3
global s s1 s2 s3 s4
global sx sy sz
global mom_out_angle_pos
global mom_pos
global rad_b rad_c
if {![string compare "5X" $dpp_path_type]} {
  set rad_b [expr $mom_out_angle_pos(0)*0.01745329252]
  set rad_c [expr $mom_out_angle_pos(1)*0.01745329252]
  #****************************Calculate X******************************
  # X = [cos4*cos5-1]*#101 + [cos4*sin5]*#102 + [-sin4]*#103 + [x]
  set e1 [expr cos($rad_b)*cos($rad_c)-1.0]
  set e2 [expr cos($rad_b)*sin($rad_c)]
  set e3 [expr -1.0*sin($rad_b)]
  set d1 [expr round($e1*1000000.0)/1000000.0]
  set d2 [expr round($e2*1000000.0)/1000000.0]
  set d3 [expr round($e3*1000000.0)/1000000.0]
  set vx [expr round($mom_pos(0)*10000.0)/10000.0]
  #////////////////////////w1/////////////////////////
  set w1 [format "%.6f" $d1]
  if {![string compare "-1.000000" $w1]} {
    set s1 "-#101"
  } elseif {![string compare "1.000000" $w1]} {
      set s1 "#101"
    } else {
        if {[string index $w1 end-0] == "0"} {
          if {[string index $w1 end-1] == "0"} {
            if {[string index $w1 end-2] == "0"} {
              if {[string index $w1 end-3] == "0"} {
                if {[string index $w1 end-4] == "0"} {
                  if {[string index $w1 end-5] == "0"} {
                     set w1 [format "%d." [expr round($d1)]]
                   } else {
                       set w1 [format "%.1f" $d1]
                 } else {
                     set w1 [format "%.2f" $d1]
               } else {
                   set w1 [format "%.3f" $d1]
             } else {
                 set w1 [format "%.4f" $d1]
           } else {
               set w1 [format "%.5f" $d1]
        if {$d1 != 0.0} {
          set s1 [format "%s*#101" $w1]
        } else {
            set s1 "NONE"
  #////////////////////////w2/////////////////////////
  set w2 [format "%.6f" $d2]
  if {![string compare "-1.000000" $w2]} {
    set s2 "-#102"
  } elseif {![string compare "1.000000" $w2]} {
      set s2 "+#102"
    } else {
        if {[string index $w2 end-0] == "0"} {
          if {[string index $w2 end-1] == "0"} {
            if {[string index $w2 end-2] == "0"} {
               if {[string index $w2 end-3] == "0"} {
                 if {[string index $w2 end-4] == "0"} {
                   if {[string index $w2 end-5] == "0"} {
                     set w2 [format "%d." [expr round($d2)]]
                   } else {
                       set w2 [format "%.1f" $d2]
                 } else {
                     set w2 [format "%.2f" $d2]
               } else {
                   set w2 [format "%.3f" $d2]
             } else {
                 set w2 [format "%.4f" $d2]
           } else {
               set w2 [format "%.5f" $d2]
        if {$d2 > 0.0} {
          set s2 [format "+%s*#102" $w2]
        } elseif {$d2 < 0.0} {
            set s2 [format "%s*#102" $w2]
          } else {
              set s2 "NONE"
  #////////////////////////w3/////////////////////////
  set w3 [format "%.6f" $d3]
  if {![string compare "-1.000000" $w3]} {
    set s3 "-#103"
  } elseif {![string compare "1.000000" $w3]} {
      set s3 "+#103"
    } else {
        if {[string index $w3 end-0] == "0"} {
          if {[string index $w3 end-1] == "0"} {
            if {[string index $w3 end-2] == "0"} {
               if {[string index $w3 end-3] == "0"} {
                 if {[string index $w3 end-4] == "0"} {
                   if {[string index $w3 end-5] == "0"} {
                     set w3 [format "%d." [expr round($d3)]]
                   } else {
                       set w3 [format "%.1f" $d3]
                 } else {
                     set w3 [format "%.2f" $d3]
               } else {
                   set w3 [format "%.3f" $d3]
             } else {
                 set w3 [format "%.4f" $d3]
           } else {
               set w3 [format "%.5f" $d3]
        if {$d3 > 0.0} {
          set s3 [format "+%s*#103" $w3]
        } elseif {$d3 < 0.0} {
            set s3 [format "%s*#103" $w3]
          } else {
              set s3 "NONE"
  #////////////////////////w4/////////////////////////
  set w4 [format "%.4f" $vx]
  if {[string index $w4 end-0] == "0"} {
    if {[string index $w4 end-1] == "0"} {
      if {[string index $w4 end-2] == "0"} {
        if {[string index $w4 end-3] == "0"} {
          set w4 [format "%d." [expr round($vx)]]
        } else {
            set w4 [format "%.1f" $vx]
      } else {
          set w4 [format "%.2f" $vx]
    } else {
        set w4 [format "%.3f" $vx]
  if {$vx > 0.0} {
    set s4 [format "+%s" $w4]
  } elseif {$vx < 0.0} {
      set s4 [format "%s" $w4]
    } else {
        set s4 "NONE"
  #///////////////////////////////////////////////////////sy///////////////////////////////////////////////////////
  if {[string compare "NONE" $s1] && [string compare "NONE" $s2] && [string compare "NONE" $s3]} {
    set s [format "%s%s%s" $s1 $s2 $s3]
  } elseif {[string compare "NONE" $s1] && ![string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
      set s $s1
    } elseif {![string compare "NONE" $s1] && [string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
        set s $s2
      } elseif {![string compare "NONE" $s1] && ![string compare "NONE" $s2] && [string compare "NONE" $s3]} {
          set s $s3
        } elseif {[string compare "NONE" $s1] && [string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
            set s [format "%s%s" $s1 $s2]
          } elseif {[string compare "NONE" $s1] && ![string compare "NONE" $s2] && [string compare "NONE" $s3]} {
              set s [format "%s%s" $s1 $s3]
            } elseif {![string compare "NONE" $s1] && [string compare "NONE" $s2] && [string compare "NONE" $s3]} {
                set s [format "%s%s" $s2 $s3]
              } else {
                  set s "NONE"
  if {[string compare "NONE" $s] && [string compare "NONE" $s4]} {
    set sx [format "\[%s%s\]" $s $s4]
  } elseif {![string compare "NONE" $s] && [string compare "NONE" $s4]} {
      set sx $s4
    } elseif {[string compare "NONE" $s] && ![string compare "NONE" $s4]} {
        set sx [format "\[%s\]" $s]
      } else {
          set sx "0."
  #******************Calculate Y**********************
  # Y = [-sin5]*#101 + [cos5-1]*#102 + [y]
  set e1 [expr -1.0*sin($rad_c)]
  set e2 [expr cos($rad_c)-1.0]
  set vy [expr round($mom_pos(1)*10000.0)/10000.0]
未完待续。。。。
35
发表于 2026-3-29 12:09:24 来自手机 | 显示全部楼层
感谢大佬分享!
发表于 2026-4-18 12:56:44 | 显示全部楼层
发表于 2026-4-18 14:47:54 | 显示全部楼层
发表于 2026-4-18 17:44:47 | 显示全部楼层
大神~!请问下组合程序后处理出来怎么让他只输出一个坐标一个进给一个转速啊?改哪里可以实现啊~~
发表于 2026-4-18 17:45:35 | 显示全部楼层
大神~~!请问下修改哪里才能实现组合程序只输出一个坐标一个转速一个进给啊?
发表于 2026-4-19 08:51:54 | 显示全部楼层
感谢楼主无私分享,支持一下,非常实用的好资源!
GMT+8, 2026-11-18 20:31
