查看: 727|回复: 3
[分享] 手把手教你制作UG四五轴宏联动后处理(十九)
发表于 2026-1-5 01:44:00 | 显示全部楼层 |阅读模式
  set w3 [format "%.6f" $d3]
  if {![string compare "-1.000000" $w3]} {
    set s3 "-#102"
  } elseif {![string compare "1.000000" $w3]} {
      set s3 "+#102"
    } else {
        if {[string index $w3 end-0] == "0"} {
          if {[string index $w3 end-1] == "0"} {
            if {[string index $w3 end-2] == "0"} {
               if {[string index $w3 end-3] == "0"} {
                 if {[string index $w3 end-4] == "0"} {
                   if {[string index $w3 end-5] == "0"} {
                     set w3 [format "%d." [expr round($d3)]]
                   } else {
                       set w3 [format "%.1f" $d3]
                 } else {
                     set w3 [format "%.2f" $d3]
               } else {
                   set w3 [format "%.3f" $d3]
             } else {
                 set w3 [format "%.4f" $d3]
           } else {
               set w3 [format "%.5f" $d3]
        if {$d3 > 0.0} {
          set s3 [format "+%s*#102" $w3]
        } elseif {$d3 < 0.0} {
            set s3 [format "%s*#102" $w3]
          } else {
              set s3 "NONE"
  set w4 [format "%.4f" $vz]
  if {[string index $w4 end-0] == "0"} {
    if {[string index $w4 end-1] == "0"} {
      if {[string index $w4 end-2] == "0"} {
        if {[string index $w4 end-3] == "0"} {
          set w4 [format "%d." [expr round($vz)]]
        } else {
            set w4 [format "%.1f" $vz]
      } else {
          set w4 [format "%.2f" $vz]
    } else {
        set w4 [format "%.3f" $vz]
  if {$vz > 0.0} {
    set s4 [format "+%s" $w4]
  } elseif {$vz < 0.0} {
      set s4 [format "%s" $w4]
    } else {
        set s4 "NONE"
  if {[string compare "NONE" $s1] && [string compare "NONE" $s2] && [string compare "NONE" $s3]} {
    set s [format "%s%s%s" $s1 $s2 $s3]
  } elseif {[string compare "NONE" $s1] && ![string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
      set s $s1
    } elseif {![string compare "NONE" $s1] && [string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
        set s $s2
      } elseif {![string compare "NONE" $s1] && ![string compare "NONE" $s2] && [string compare "NONE" $s3]} {
          set s $s3
        } elseif {[string compare "NONE" $s1] && [string compare "NONE" $s2] && ![string compare "NONE" $s3]} {
            set s [format "%s%s" $s1 $s2]
          } elseif {[string compare "NONE" $s1] && ![string compare "NONE" $s2] && [string compare "NONE" $s3]} {
              set s [format "%s%s" $s1 $s3]
            } elseif {![string compare "NONE" $s1] && [string compare "NONE" $s2] && [string compare "NONE" $s3]} {
                set s [format "%s%s" $s2 $s3]
              } else {
                  set s "NONE"
  if {[string compare "NONE" $s] && [string compare "NONE" $s4]} {
    set sz [format "\[%s%s\]" $s $s4]
  } elseif {![string compare "NONE" $s] && [string compare "NONE" $s4]} {
      set sz $s4
    } elseif {[string compare "NONE" $s] && ![string compare "NONE" $s4]} {
        set sz [format "\[%s\]" $s]
      } else {
          set sz "0."
  return 1
return 0
  点击确定。
8.在"程序和刀轨"选项卡中,选择左侧"工序结束序列"选项,在"刀轨结束"事件下添加G91 G28 Z0.行。
9.在"程序和刀轨"选项卡中,选择左侧"程序结束序列"选项:
  (1).在"程序结束"事件下添加G91 G28 X0. Y0. M9行。
  (2).在"程序结束"事件下的G91 G28 X0. Y0. M9行下面添加G91 G28 B0. C0. M5行。
  (3).在"程序结束"事件下的G91 G28 B0. C0. M5行下面添加M30行。
  (4).在"程序结束"事件下的M30行下面添加%行。
10.保存后处理文件。
11.五轴双转台BC宏联动后处理制作完成。
(五).制作立加四轴A转台宏联动后处理:
1.打开NX后处理构造器,新建一个后处理。
2.输入后处理名称vmc_4x_rtcp_A,选中主后处理,后处理输出单位选择毫米,
   机床选择4轴带转台,控制器选择一般,点击确定。
3.在"机床"选项卡中,选择左侧"第四轴"选项,将"轴限制(度)->最大值"改成360,
  "轴限制(度)->最小值"改成0,轴限制可以根据具体机床设置。
   点击"选择轴->配置"按钮,将"第四轴转台->旋转平面"改成YZ,将"文字引导符"改成A,
   将"最大进给率(度/分)"改成1000,将"线性插值->旋转角度->默认公差"改成0.001,点击确定。
4.在"程序和刀轨"选项卡中,选择左侧"程序起始序列"选项,右侧出现"程序开始"事件页面:
  (1).点击定制命令PB_CMD___log_revisions,输入如下TCL代码:
      #变量dpp_path_type用来判断工序刀路类型:三轴/定轴/四轴联动
      global dpp_path_type
      global dpp_flag
      set dpp_path_type "NONE"
      set dpp_flag 0
      点击确定。
  (2).删除MOM_set_seq_on行。
  (3).将G40 G17 G90 G71条目内容改成G17 G40 G80 G69 G49 G94 G90。
  (4).在G17 G40 G80 G69 G49 G94 G90行下面添加定制命令行,
      输入名称PB_CMD_init_macro,输入以下TCL代码:
      MOM_output_literal "#101=#5261-#5241"
      MOM_output_literal "#102=#5262-#5242"
      MOM_output_literal "#103=#5263-#5243"
      点击确定。
5.在"程序和刀轨"选项卡中,选择左侧"工序起始序列"选项:
  (1).将"刀轨开始"事件下的定制命令PB_CMD_start_of_operation_force_adress
      里面的内容改成如下TCL代码:
      global dpp_flag
      MOM_force once S M_spindle X Y Z fourth_axis fifth_axis F
      if { $dpp_flag != 0 } {
         MOM_output_literal "M1"
      点击确定。
  (2).在PB_CMD_start_of_operation_force_adress行下面添加操作员消息行,
      输入"工序: $mom_operation_name"(双引号无需输入),点击确定。
  (3).复制"自动换刀"事件下的PB_CND_tool_change_force_adress行到"第一个刀具"事件下面。
  (4).在"第一个刀具"事件下的PB_CND_tool_change_force_adress行下面添加MOM_set_seq_on行。
  (5).在"第一个刀具"事件下的MOM_set_seq_on行下面添加T M6行。
  (6).在"第一个刀具"事件下的T M6行下面添加MOM_set_seq_off行。
  (7).在"第一个刀具"事件下的MOM_set_seq_off行下面添加操作员消息行,
      输入"刀具: $mom_tool_name"(双引号无需输入),点击确定。
  (8).在"第一个刀具"事件下的"刀具: $mom_tool_name"行下面添加备刀T行。
  (9).将"自动换刀"事件下的G91 G28 Z0.行内容改成G91 G28 Z0. M9。
  (10).在"自动换刀"事件下的G91 G28 Z0. M9行下面添加G91 G28 X0. Y0. M5行。
  (11).在"自动换刀"事件下的T M6行上面添加MOM_set_seq_on行。
  (12).在"自动换刀"事件下的T M6行下面添加MOM_set_seq_off行。
  (13).在"自动换刀"事件下的MOM_set_seq_off行下面添加操作员消息行,
  (14).在"自动换刀"事件下的"刀具: $mom_tool_name"行下面添加备刀T行。
  (15).在"初始移动"事件下添加定制命令行,输入名称PB_CMD_detect_tool_path_type,
       编辑TCL代码如下:
       global dpp_flag
       global mom_tool_axis_type
       global mom_operation_type
       set dpp_flag 1
       if { ![info exists mom_tool_axis_type] } {
          set mom_tool_axis_type 0
       if { $mom_tool_axis_type >= 2 && [string match "Variable-axis *" $mom_operation_type] } {
         set dpp_path_type "4X"
      } else {
          set dpp_path_type "3X"
      点击确定。
未完待续。。。。
35
发表于 2026-3-27 14:00:45 来自手机 | 显示全部楼层
感谢大佬分享,大佬牛掰!
发表于 2026-3-28 18:30:10 | 显示全部楼层
大佬牛掰!
发表于 2026-4-19 08:34:10 | 显示全部楼层
感谢楼主无私分享,支持一下,非常实用的好资源!
GMT+8, 2026-11-18 20:31
