查看: 683|回复: 6
[分享] 手把手教你制作UG四五轴宏联动后处理(二十一)
发表于 2026-1-6 08:11:48 | 显示全部楼层 |阅读模式
  #******************计算Zrtcp*******************
  set e1 [expr -1.0*sin($rad_a)]
  set e2 [expr cos($rad_a)-1.0]
  set d1 [expr round($e1*1000000.0)/1000000.0]
  set d2 [expr round($e2*1000000.0)/1000000.0]
  set vz [expr round($mom_pos(2)*10000.0)/10000.0]
  set w1 [format "%.6f" $d1]
  if {![string compare "-1.000000" $w1]} {
    set s1 "-#102"
  } elseif {![string compare "1.000000" $w1]} {
      set s1 "#102"
    } else {
        if {[string index $w1 end-0] == "0"} {
          if {[string index $w1 end-1] == "0"} {
            if {[string index $w1 end-2] == "0"} {
              if {[string index $w1 end-3] == "0"} {
                if {[string index $w1 end-4] == "0"} {
                  if {[string index $w1 end-5] == "0"} {
                     set w1 [format "%d." [expr round($d1)]]
                   } else {
                       set w1 [format "%.1f" $d1]
                 } else {
                     set w1 [format "%.2f" $d1]
               } else {
                   set w1 [format "%.3f" $d1]
             } else {
                 set w1 [format "%.4f" $d1]
           } else {
               set w1 [format "%.5f" $d1]
        if {$d1 != 0.0} {
          set s1 [format "%s*#102" $w1]
        } else {
            set s1 "NONE"
  set w2 [format "%.6f" $d2]
  if {![string compare "-1.000000" $w2]} {
    set s2 "-#103"
  } elseif {![string compare "1.000000" $w2]} {
      set s2 "+#103"
    } else {
        if {[string index $w2 end-0] == "0"} {
          if {[string index $w2 end-1] == "0"} {
            if {[string index $w2 end-2] == "0"} {
               if {[string index $w2 end-3] == "0"} {
                 if {[string index $w2 end-4] == "0"} {
                   if {[string index $w2 end-5] == "0"} {
                     set w2 [format "%d." [expr round($d2)]]
                   } else {
                       set w2 [format "%.1f" $d2]
                 } else {
                     set w2 [format "%.2f" $d2]
               } else {
                   set w2 [format "%.3f" $d2]
             } else {
                 set w2 [format "%.4f" $d2]
           } else {
               set w2 [format "%.5f" $d2]
        if {$d2 > 0.0} {
          set s2 [format "+%s*#103" $w2]
        } elseif {$d2 < 0.0} {
            set s2 [format "%s*#103" $w2]
          } else {
              set s2 "NONE"
  set w4 [format "%.4f" $vz]
  if {[string index $w4 end-0] == "0"} {
    if {[string index $w4 end-1] == "0"} {
      if {[string index $w4 end-2] == "0"} {
        if {[string index $w4 end-3] == "0"} {
          set w4 [format "%d." [expr round($vz)]]
        } else {
            set w4 [format "%.1f" $vz]
      } else {
          set w4 [format "%.2f" $vz]
    } else {
        set w4 [format "%.3f" $vz]
  if {$vz > 0.0} {
    set s4 [format "+%s" $w4]
  } elseif {$vz < 0.0} {
      set s4 [format "%s" $w4]
    } else {
        set s4 "NONE"
  if {[string compare "NONE" $s1] && ![string compare "NONE" $s2]} {
    set s $s1
  } elseif {![string compare "NONE" $s1] && [string compare "NONE" $s2]} {
      set s $s2
    } elseif {[string compare "NONE" $s1] && [string compare "NONE" $s2]} {
        set s [format "%s%s" $s1 $s2]
      } else {
          set s "NONE"
  if {[string compare "NONE" $s] && [string compare "NONE" $s4]} {
    set sz [format "\[%s%s\]" $s $s4]
  } elseif {![string compare "NONE" $s] && [string compare "NONE" $s4]} {
      set sz $s4
    } elseif {[string compare "NONE" $s] && ![string compare "NONE" $s4]} {
        set sz [format "\[%s\]" $s]
      } else {
          set sz "0."
  return 1
return 0
       点击确定。
  (22).将"初始移动"事件下的G0 G90 G(54~59) 文本元素1 文本元素2 A S M3行复制到"第一次移动"事件下的G0 G90 (54~59) X Y A S M3行下面。
  (23).在"初始移动"事件下的G0 G90 G(54~59) 文本元素1 文本元素2 A S M3行下面添加G43 Z H1 M8行,
       添加输出条件PB__CMD_check_block_initial_move2,编辑TCL代码如下:
       global dpp_path_type
       if {![string compare "3X" $dpp_path_type]} {
          return 1
       return 0
       点击确定。
  (24).将"初始移动"事件下的G43 Z H1 M8行复制到"第一次移动"事件下的G0 G90 (54~59) 文本元素1 文本元素2 X Y A S M3行下面。
  (25).在"初始移动"事件下的G43 Z H1 M8行下面添加G43 文本元素 H1 M8行,将文本元素内容改为Z$sz,
       添加输出条件PB__CMD_check_block_initial_move3,编辑TCL代码如下:
       if {![string compare "5X" $dpp_path_type]} {
         return 1
       return 0
       点击确定。
  (26).将"初始移动"事件下的G43 文本元素 H1 M8行复制到"第一次移动"事件下的G43 Z H1 M8行下面。
6.在"程序和刀轨"选项卡中,选择左侧"运动"选项:
  (1).将"圆周移动"事件下的G17 G2 G90 X Y Z I J K F S行中的G17和S元素删除,将G2元素设置为强制输出,
      添加输出条件PB__CMD_check_block_circular_move,编辑TCL代码如下:
        return 1
      return 0
      点击确定。
  (2).将"线性移动"事件下的G41 G17 G1 G90 X Y Z A F S D1 M3 M8行中的G17,S,M3,M8元素删除,
      添加输出条件PB__CMD_check_block_linear_move,编辑TCL代码如下:
        return 1
      return 0
      点击确定。
  (3).在"线性移动"事件下的G41 G1 G90 X Y Z A F D1行下面添加G41 G1 G90 文本元素 A F D1行,
       将文本元素内容改为X$sx Y$sy Z$sz,添加输出条件PB_CMD__check_block_linear_move_1,
       编辑TCL代码如下:
global e1 e2 d1 d2 vx vy vz rad_a
global w1 w2 w4
global s s1 s2 s4
global sx sy sz
global mom_pos mom_out_angle_pos
if {![string compare "4X" $dpp_path_type]} {
  set rad_a [expr $mom_out_angle_pos(0)*0.01745329252]
  #*********************计算Xrtcp***********************
  set vx [expr round($mom_pos(0)*10000.0)/10000.0]
  set w4 [format "%.4f" $vx]
          set w4 [format "%d." [expr round($vx)]]
        } else {
            set w4 [format "%.1f" $vx]
      } else {
          set w4 [format "%.2f" $vx]
    } else {
        set w4 [format "%.3f" $vx]
  set sx $w4
未完待续。。。。
发表于 2026-1-13 16:21:46 | 显示全部楼层
按你的步骤一步一步设置了,还是有问题,无法输出正确的代码?四轴无法输出代码,五轴直接报错,大神看看哪里有问题?
发表于 2026-1-13 16:22:48 | 显示全部楼层
按你的步骤一步一步设置。发现四轴后处理代码无法输出。五轴直接报错,无法输出代码。大神看一下哪里还有问题?求指教。
发表于 2026-1-13 16:40:31 | 显示全部楼层
FGDFG99 发表于 2026-1-13 16:22
按你的步骤一步一步设置。发现四轴后处理代码无法输出。五轴直接报错,无法输出代码。大神看一下哪里还有问 ...
做这个你得有点基础知识,他这个代码里面又得漏泄活多写得错误,要自己改下
34
发表于 2026-1-13 18:26:26 | 显示全部楼层
做这个后处理要有点做后处理的功底,做完要试后处理,试完有问题要修改。要看报错是什么?根据报错修改。刚开始我按步骤做也报错,后来发现有些是给的条件少了括号,有些是需要调整 。所以跟着做也不是直接可以做好的。
35
发表于 2026-3-27 13:48:30 来自手机 | 显示全部楼层
感谢分享!
发表于 2026-4-19 08:18:18 | 显示全部楼层
感谢楼主无私分享,支持一下,非常实用的好资源!
GMT+8, 2026-11-18 20:31
