查看: 700|回复: 4
[分享] 手把手教你制作UG四五轴宏联动后处理(二十二)
发表于 2026-1-6 08:13:34 | 显示全部楼层 |阅读模式
  #****************计算Yrtcp*****************
  set e1 [expr cos($rad_a)-1.0]
  set e2 [expr sin($rad_a)]
  set d1 [expr round($e1*1000000.0)/1000000.0]
  set d2 [expr round($e2*1000000.0)/1000000.0]
  set vy [expr round($mom_pos(1)*10000.0)/10000.0]
  set w1 [format "%.6f" $d1]
  if {![string compare "-1.000000" $w1]} {
    set s1 "-#102"
  } elseif {![string compare "1.000000" $w1]} {
      set s1 "#102"
    } else {
        if {[string index $w1 end-0] == "0"} {
          if {[string index $w1 end-1] == "0"} {
            if {[string index $w1 end-2] == "0"} {
              if {[string index $w1 end-3] == "0"} {
                if {[string index $w1 end-4] == "0"} {
                  if {[string index $w1 end-5] == "0"} {
                     set w1 [format "%d." [expr round($d1)]]
                   } else {
                       set w1 [format "%.1f" $d1]
                 } else {
                     set w1 [format "%.2f" $d1]
               } else {
                   set w1 [format "%.3f" $d1]
             } else {
                 set w1 [format "%.4f" $d1]
           } else {
               set w1 [format "%.5f" $d1]
        if {$d1 != 0.0} {
          set s1 [format "%s*#102" $w1]
        } else {
            set s1 "NONE"
  set w2 [format "%.6f" $d2]
  if {![string compare "-1.000000" $w2]} {
    set s2 "-#103"
  } elseif {![string compare "1.000000" $w2]} {
      set s2 "+#103"
    } else {
        if {[string index $w2 end-0] == "0"} {
          if {[string index $w2 end-1] == "0"} {
            if {[string index $w2 end-2] == "0"} {
               if {[string index $w2 end-3] == "0"} {
                 if {[string index $w2 end-4] == "0"} {
                   if {[string index $w2 end-5] == "0"} {
                     set w2 [format "%d." [expr round($d2)]]
                   } else {
                       set w2 [format "%.1f" $d2]
                 } else {
                     set w2 [format "%.2f" $d2]
               } else {
                   set w2 [format "%.3f" $d2]
             } else {
                 set w2 [format "%.4f" $d2]
           } else {
               set w2 [format "%.5f" $d2]
        if {$d2 > 0.0} {
          set s2 [format "+%s*#103" $w2]
        } elseif {$d2 < 0.0} {
            set s2 [format "%s*#103" $w2]
          } else {
              set s2 "NONE"
  set w4 [format "%.4f" $vy]
  if {[string index $w4 end-0] == "0"} {
    if {[string index $w4 end-1] == "0"} {
      if {[string index $w4 end-2] == "0"} {
        if {[string index $w4 end-3] == "0"} {
          set w4 [format "%d." [expr round($vy)]]
        } else {
            set w4 [format "%.1f" $vy]
      } else {
          set w4 [format "%.2f" $vy]
    } else {
        set w4 [format "%.3f" $vy]
  if {$vy > 0.0} {
    set s4 [format "+%s" $w4]
  } elseif {$vy < 0.0} {
      set s4 [format "%s" $w4]
    } else {
        set s4 "NONE"
  if {[string compare "NONE" $s1] && ![string compare "NONE" $s2]} {
    set s $s1
  } elseif {![string compare "NONE" $s1] && [string compare "NONE" $s2]} {
      set s $s2
    } elseif {[string compare "NONE" $s1] && [string compare "NONE" $s2]} {
        set s [format "%s%s" $s1 $s2]
      } else {
          set s "NONE"
  if {[string compare "NONE" $s] && [string compare "NONE" $s4]} {
    set sy [format "\[%s%s\]" $s $s4]
  } elseif {![string compare "NONE" $s] && [string compare "NONE" $s4]} {
      set sy $s4
    } elseif {[string compare "NONE" $s] && ![string compare "NONE" $s4]} {
        set sy [format "\[%s\]" $s]
      } else {
          set sy "0."
  #****************计算Zrtcp******************
  set e1 [expr -1.0*sin($rad_a)]
  set e2 [expr cos($rad_a)-1.0]
  set vz [expr round($mom_pos(2)*10000.0)/10000.0]
    set s1 "-#102"
      set s1 "#102"
    } else {
                   } else {
                 } else {
               } else {
             } else {
           } else {
        if {$d1 != 0.0} {
        } else {
            set s1 "NONE"
    set s2 "-#103"
      set s2 "+#103"
    } else {
                   } else {
                 } else {
               } else {
             } else {
           } else {
        if {$d2 > 0.0} {
          } else {
              set s2 "NONE"
未完待续。。。。
35
发表于 2026-3-29 12:08:36 来自手机 | 显示全部楼层
感谢大佬分享!
发表于 2026-3-30 08:08:03 | 显示全部楼层
虽然看不懂,但是感新大老的分享哦
发表于 2026-4-18 12:58:41 | 显示全部楼层
发表于 2026-4-19 07:43:12 | 显示全部楼层
感谢楼主无私分享,支持一下,非常实用的好资源!
GMT+8, 2026-11-18 20:31
