楼主: 秋风5685
[分享] 支持六个系统共用后处理
 火.. [复制链接]
 楼主| 发表于 2026-1-17 20:22:33 | 显示全部楼层
# Exported Custom Commands created by Administrator
# on 2017Äê12ÔÂ22ÈÕ ÐÇÆÚÎå 23:36:03 中国标准时间
proc PB_CMD_init_helix { } {
uplevel #0 {
# This ommand will be executed automatically at the start of program and
# anytime it is loaded as a slave post of a linked post.
# This procedure can be used to enable your post to output helix.
# You can choose from the following options to format the circle
# block template to output the helix parameters.
set mom_sys_helix_pitch_type    "rise_radian"
# The default setting for mom_sys_helix_pitch_type is "rise_radian".
# This is the most common.  Other choices are:
#    "rise_radian"              Measures the rise over one radian.
#    "rise_revolution"          Measures the rise over 360 degrees.
#    "none"                     Will suppress the output of pitch.
#    "other"                    Allows you to calculate the pitch
#                               using your own formula.
# This custom command uses the block template circular_move to output
# the helix block.  If your post uses a block template with a different
# name, you must edit the line that outputs the helix block.
#  The following variable deines the output mode for helical records.
#  FULL_CIRCLE  -- This mode will output a helix record for each 360
#                  degrees of the helix.
#  QUADRANT  --    This mode will output a helix record for each 90
#  LINEAR  --      This mode will output the entire helix as linear gotos.
#  END_POINT --    This mode will assume the control can define an entire
#                  helix in a single block.
   set mom_kin_helical_arc_output_mode FULL_CIRCLE
   MOM_reload_kinematics
proc MOM_helix_move { } {
   global mom_pos_arc_plane
   global mom_sys_cir_vector
   global mom_sys_helix_pitch_type
   global mom_helix_pitch
   global mom_prev_pos mom_pos_arc_center
   global PI
   switch $mom_pos_arc_plane {
      XY { MOM_suppress once K ; set cir_index 2 }
      YZ { MOM_suppress once I ; set cir_index 0 }
      ZX { MOM_suppress once J ; set cir_index 1 }
   switch $mom_sys_helix_pitch_type {
      none { }
      rise_revolution { set pitch $mom_helix_pitch }
      rise_radian { set pitch [expr $mom_helix_pitch / ($PI * 2.0)]}
      other {
#    Place your custom helix pitch code here
      default { set mom_sys_helix_pitch_type "none" }
   MOM_force once X Y Z
   if { [string compare "none" $mom_sys_helix_pitch_type] } {
      MOM_force once I J K
#<08-01-06 gsl>
      switch $mom_sys_cir_vector {
         "Vector - Arc Center to Start" {
            set mom_prev_pos($cir_index) $pitch
            set mom_pos_arc_center($cir_index) 0.0
         "Vector - Arc Start to Center" -
         "Unsigned Vector - Arc Start to Center" {
            set mom_prev_pos($cir_index) 0.0
            set mom_pos_arc_center($cir_index) $pitch
         "Vector - Absolute Arc Center" {
# You may need to edit this line if you output more than one block
# or if you have changed the name of your circular_move block template
   MOM_do_template circular_move
} ;# MOM_helix_move
} ;# uplevel
 楼主| 发表于 2026-1-17 20:34:48 | 显示全部楼层
更新UG六个主流数控系统后处理.rar (905.21 KB, 下载次数: 539) 更新组内多坐标混合使用方式问题!更新ijk输出问题!
发表于 2026-1-17 21:32:18 | 显示全部楼层
感谢楼主分享
发表于 2026-1-18 08:25:46 来自手机 | 显示全部楼层
厉害了,一下解决了。
发表于 2026-1-18 11:43:12 | 显示全部楼层
发表于 2026-1-18 13:38:08 | 显示全部楼层
您好,后处理自动打开CIMCOEdit后,如果不结束CIMCOEdit进程,UG会进入假死状态,除非关了CIMCOEdit,才能继续操作UG
发表于 2026-1-18 14:20:31 | 显示全部楼层
那个高精代码是否可以给个设置,开启或者关闭
发表于 2026-1-18 19:40:35 来自手机 | 显示全部楼层
攻牙怎么设置呢
发表于 2026-1-18 21:00:53 | 显示全部楼层
支持四轴联动加工吗
发表于 2026-1-19 13:58:12 | 显示全部楼层
感谢楼主的无私奉献
GMT+8, 2026-11-18 20:01
