查看: 662|回复: 2
[分享] UG 装配体一键 随机改颜色
发表于 2026-7-21 22:24:35 | 显示全部楼层 |阅读模式
UG 装配体一键 随机改颜色的插件
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Module RandomColorAssembly
    Dim theSession As Session = Session.GetSession()
    Dim partColorDict As New Dictionary(Of String, Integer)(StringComparer.OrdinalIgnoreCase)
    Dim partBodyColored As New Dictionary(Of String, Boolean)(StringComparer.OrdinalIgnoreCase)
    Dim rand As New Random()
    Sub Main()
        Dim workPart As Part = theSession.Parts.Work
        If workPart Is Nothing Then
            Return
        End If
        ' 先完全加载当前工作部件(装配体则连同其下所有组件一并加载),避免后续 "Part is only partially loaded"
        Dim loadStatus As PartLoadStatus = Nothing
        Try
            loadStatus = workPart.LoadFully()
            If loadStatus IsNot Nothing Then loadStatus.Dispose()
        Catch ex As Exception
        End Try
        ' 如果是装配体,递归遍历组件;否则按单零件处理
        Dim rootComp As Assemblies.Component = Nothing
        Try
            If workPart.ComponentAssembly IsNot Nothing AndAlso workPart.ComponentAssembly.RootComponent IsNot Nothing Then
                rootComp = workPart.ComponentAssembly.RootComponent
            End If
        Catch ex As NXException
            ' 装配仅部分加载时 RootComponent 可能抛 "Part is only partially loaded"
            rootComp = Nothing
        End Try
        If rootComp IsNot Nothing Then
            partColorDict.Clear()
            partBodyColored.Clear()
            ColorComponentsRecursively(rootComp, rootComp)
        Else
            ColorSinglePart(workPart)
        End If
    End Sub
    ' 安全获取组件的 OwningPart,遇“仅部分加载”等异常时返回 Nothing
    Function TryGetPartFromComponent(ByVal comp As Assemblies.Component) As Part
        If comp Is Nothing Then Return Nothing
        Try
            If comp.Prototype Is Nothing Then Return Nothing
            Dim p As Part = comp.Prototype.OwningPart
            Return p
            Return Nothing
            Return Nothing
        End Try
    End Function
    Sub ColorComponentsRecursively(ByVal comp As Assemblies.Component, ByVal rootComp As Assemblies.Component)
        If IsLeafComponent(comp) Then
            Dim part As Part = TryGetPartFromComponent(comp)
            If part IsNot Nothing Then
                Dim colorIndex As Integer = GetOrCreateColorForPart(part)
                Try
                    ' 装配中:先改组件显示
                    ApplyColorToComponent(comp, colorIndex)
                End Try
                ' 临时切到该零件为工作部件,给本体上色并保存,这样单独打开时才有颜色(每零件只做一次)
                Dim key As String = part.Leaf
                If Not partBodyColored.ContainsKey(key) Then
                    Try
                        Dim partLoadStatus As PartLoadStatus = Nothing
                        theSession.Parts.SetWorkComponent(comp, PartCollection.RefsetOption.Entire, PartCollection.WorkComponentOption.Visible, partLoadStatus)
                        Dim partAsWork As Part = theSession.Parts.Work
                        If partAsWork IsNot Nothing Then
                            ApplyColorToPartBodies(partAsWork, colorIndex)
                            partAsWork.Save(BasePart.SaveComponents.True, BasePart.CloseAfterSave.False)
                        End If
                        partBodyColored(key) = True
                    Finally
                        ' 切回装配为工作部件
                        Try
                            Dim partLoadStatusBack As PartLoadStatus = Nothing
                            theSession.Parts.SetWorkComponent(rootComp, PartCollection.RefsetOption.Entire, PartCollection.WorkComponentOption.Visible, partLoadStatusBack)
                        Catch ex2 As Exception
                        End Try
                    End Try
                End If
            End If
        End If
        ' 仅部分加载的组件 GetChildren 可能抛 NXException,需捕获后跳过子级
        Try
            For Each child As Assemblies.Component In comp.GetChildren()
                ColorComponentsRecursively(child, rootComp)
            Next
            ' 部分加载时跳过该分支的子组件
        End Try
    End Sub
    Sub ColorSinglePart(ByVal part As Part)
        If part Is Nothing Then Return
        Try
            ApplyColorToPartBodies(part, colorIndex)
            part.Save(BasePart.SaveComponents.True, BasePart.CloseAfterSave.False)
        End Try
    End Sub
    Function GetOrCreateColorForPart(ByVal part As Part) As Integer
        If part Is Nothing Then Return 0
        ' 先看内存中是否已经有该零件名的颜色
        If partColorDict.TryGetValue(key, colorIndex) Then
            Return colorIndex
        End If
        ' 再尝试从零件属性中读取
        Dim attrColor As Integer = GetColorFromAttribute(part)
        If attrColor > 0 Then
            colorIndex = attrColor
        Else
            colorIndex = rand.Next(1, 217)
        End If
        ' 写入字典和零件属性
        partColorDict(key) = colorIndex
        SaveColorToAttribute(part, colorIndex)
        Return colorIndex
    End Function
    Function GetColorFromAttribute(ByVal part As Part) As Integer
        Try
            Dim nxObj As NXObject = CType(part, NXObject)
            ' 优先使用 HasUserAttribute / GetIntegerUserAttribute,兼容性更好
            If nxObj.HasUserAttribute("RandomColorIndex", NXObject.AttributeType.Integer, -1) Then
                Dim val As Integer = nxObj.GetIntegerUserAttribute("RandomColorIndex", -1)
                Return val
            End If
        End Try
        Return -1
    End Function
    Sub SaveColorToAttribute(ByVal part As Part, ByVal colorIndex As Integer)
        Try
            ' 第 2 个参数是属性索引,任意固定整数即可
            nxObj.SetUserAttribute("RandomColorIndex", 1, colorIndex, Update.Option.Now)
        End Try
    End Sub
    Sub ApplyColorToComponent(ByVal comp As Assemblies.Component, ByVal colorIndex As Integer)
        Dim displayMod As DisplayModification = Nothing
        Try
            displayMod = theSession.DisplayManager.NewDisplayModification()
            displayMod.NewColor = colorIndex
            displayMod.ApplyToAllFaces = True
            displayMod.Apply(New DisplayableObject() {comp})
        Finally
            If displayMod IsNot Nothing Then
                displayMod.Dispose()
            End If
        End Try
    End Sub
    Sub ApplyColorToPartBodies(ByVal part As Part, ByVal colorIndex As Integer)
        Dim bodies() As Body = part.Bodies.ToArray()
        If bodies Is Nothing OrElse bodies.Length = 0 Then Return
        Dim objs(bodies.Length - 1) As DisplayableObject
        For i As Integer = 0 To bodies.Length - 1
            objs(i) = bodies(i)
        Next
        Try
            ' 颜色写入零件本体,单独打开时才能看到
            displayMod.ApplyToOwningParts = True
            displayMod.Apply(objs)
        Finally
            End If
        End Try
    End Sub
    ' 叶子组件:对应的是零件文件(不是子装配),需要上色
    Function IsLeafComponent(ByVal comp As Assemblies.Component) As Boolean
        If comp Is Nothing Then Return False
        If part Is Nothing Then Return False
        ' 子装配有 RootComponent,只给“零件”上色(访问 RootComponent 时部分加载会抛异常)
        Try
            If part.ComponentAssembly IsNot Nothing AndAlso part.ComponentAssembly.RootComponent IsNot Nothing Then
                Return False
            End If
            ' 部分加载时当作叶子组件处理,避免再次访问
            Return True
            Return True
        End Try
        Return True
    End Function
    Public Function GetUnloadOption(ByVal dummy As String) As Integer
        Return Session.LibraryUnloadOption.Immediately
    End Function
End Module
 楼主| 发表于 2026-7-21 22:26:04 | 显示全部楼层
另存为   .vb文件,即可在ug中运行该宏程序
发表于 2026-8-7 11:04:19 | 显示全部楼层
感谢分享,支持一下
GMT+8, 2026-10-25 14:31
