查看: 14756|回复: 3
[分享] NX1847加工模块更新了许多实用的新功能
中将
论坛贡献灌水王
发表于 2019-1-25 11:59:46 | 显示全部楼层 |阅读模式
                        What's new in NX CAM 1847?
                                         Stephanie        Community Manager
        Report Inappropriate Content        27 Views
                        9 hours ago
Are you curious about what’s new in NX CAM 1847?   Watch the series of “tech tip” videos to learn how the capabilities will help you gain productivity and improve part quality.
Let us know what you think of the new capabilities in the Comment section below.
Collison Report for Guiding Curves
Variable Guiding Curves operations now detect and analyze gouges.
Bottom-up Cutting in Adaptive Milling
In Adaptive Milling, Bottom Up Cutting now controls stock removal between cut levels.
Cycles with References Generic Motion
Easily create cycle-based Generic Motion operations that can be templatized for reuse.
Turning Tool Holder Enhancements
Multiple enhancements allow further definition of holders for standard turning tools.
Gouge Check and IPW for Multi Tools
NX now supports material removal, collision check, and gouge check for multi-tools during Machine Code Based machine tool simulation.
Custom Feeds and Speeds
Custom Feed and Speed parameters for closed area engages can now be specicied in Cavity Mill, Rest Milling, Corner Rough, Floor and Wall, and Planar Mill operations.
Merge Tool Paths
Multiple operations can now be combined into a single operation containing a single merged tool path.
Coolant for Open and Closed Areas
Coolant options can now be specified separately for Open and Closed Areas in Planar, Cavity, Floor and Wall, and Adaptive Mill Operations.
Highlight Collisions in Machine Code Based Simulation
When performing Machine Code Based Simulation, collisions and gouges now highlight when you stop the simulation and drag the machine tool axis sliders or type in values.
Tube Milling Enhancements
Tube Roughing and Tube Finishing operations can now create the central curve automatically based on the specified Cut Area.
Customize Cut Level Items into Dialogs
New customizable Cut Levels items are now available for Cavity Mill, Zlevel Mill, Variable Axis Zlevel Mill, and Plunge Mill operation dialog boxes that allows you to flatten the dialog box structure.
111
推广达人
发表于 2019-1-25 15:13:14 | 显示全部楼层
你自己也看不明白说了什么吧~!
发表于 2019-5-18 22:33:13 | 显示全部楼层
b4585830 发表于 2019-1-25 15:13
你自己也看不明白说了什么吧~!
你难道不知道浏览器有翻译功能么
爱好者终身VIP
灌水王VIP会员
发表于 2019-7-7 16:26:59 | 显示全部楼层
我来翻译一下 {:}
你对NX Cam 1847的新功能好奇吗?观看一系列“技术提示”视频,了解这些功能如何帮助您提高生产效率和提高零件质量。
请在下面的评论部分告诉我们您对新功能的看法。
导向曲线的Collison报告
可变导向曲线操作现在检测和分析凿槽。
自适应铣削中的自下而上切削
在自适应铣削中,自下而上的切削现在控制切削水平之间的物料去除。
带参考的循环一般运动
轻松创建基于循环的通用运动操作,这些操作可以模板化以供重用。
车刀座加强件
多个增强功能允许进一步定义标准车刀的刀架。
多刀具的凿槽检查和IPW
NX现在支持在基于机器代码的机床仿真过程中对多个刀具进行材料去除、碰撞检查和凿槽检查。
自定义源和速度
封闭区域啮合的定制进给和速度参数现在可以在型腔磨、其余磨、角粗加工、地板和墙壁以及平面磨操作中指定。
合并刀具路径
现在可以将多个操作组合成包含单个合并刀具路径的单个操作。
打开和关闭区域的冷却液
现在可以分别为平面、空腔、地板和墙壁中的打开和关闭区域以及自适应磨机操作指定冷却液选项。
基于机器代码的仿真中的冲突突出
当执行基于机器代码的模拟时,当停止模拟并拖动机床轴滑块或键入值时,碰撞和凿槽现在会突出显示。
管子铣削增强
管子粗加工和管子精加工操作现在可以根据指定的切割区域自动创建中心曲线。
自定义将级别项目剪切到对话框中
新的可自定义切割级别项目现在可用于型腔磨机、zlevel磨机、可变轴zlevel磨机和插入式磨机操作对话框,这些对话框允许您展平对话框结构。
标签:
NX 1847型
NX凸轮
NX凸轮1847
GMT+8, 2026-11-23 16:35
